Multi shard vs Multi index (Assuming same data)
I'm currently working on a project where I have quite a bit of freedom in the structure and size of data. Now, I'm wondering if there's performance difference between the following two scenarios:
Assuming a two node setup with identical hardware
Scenario 1:
  • 1 Index with 2 Shards, 1 replica
  • Shard 1 contains data A
  • Shard 2 contains data B
Scenario 2:
  • 2 Indices with 1 Shard, 1 replica
  • Index 1 contains data A
  • Index 2 contains data B
Similar concepts can be thought up with 3 or 4 shards where the data would be split evenly in 3 or 4 shards on one index or 1 shard for each of the 3 or 4 indices.
In all honesty I'm expecting an answer to be that they have similar performance.
If that's the case I wonder if adding an extra node will have equal impact on both scenario's or will one scale better than the other?
It is the same. Querying one index with X primary shards is the same as querying X indices each with 1 primary shard.
