Hi all... I've using the helm chart for Elastic -search, Filebeat, Logstash and Kibana.
Version is 8.5.1 environment in kubernetes AKS.
Issue is Logstash not recognize the elastic-search.
I need proper installation guide for this stack...
I'll show my conf in the values.yaml for logstash.
replicas: 1
# Allows you to add any config files in /usr/share/logstash/config/
# such as logstash.yml and log4j2.properties
# Note that when overriding logstash.yml, `http.host: 0.0.0.0` should always be included
# to make default probes work.
logstashConfig: {}
# logstash.yml: |
# key:
# nestedkey: value
# log4j2.properties: |
# key = value
# Allows you to add any pipeline files in /usr/share/logstash/pipeline/
### ***warn*** there is a hardcoded logstash.conf in the image, override it first
logstashPipeline:
logstash.conf: |
beats {
port => 5044
hosts => ["https://${ELASTICSEARCH_HOSTS:elasticsearch-master:9200}"]
user => "${ELASTICSEARCH_USERNAME}"
password => "${ELASTICSEARCH_PASSWORD}"
ssl => true
cacert => "/usr/share/logstash/certs/ca.crt"
# Allows you to add any pattern files in your custom pattern dir
logstashPatternDir: "/usr/share/logstash/patterns/"
logstashPattern: {}
# pattern.conf: |
# DPKG_VERSION [-+~<>\.0-9a-zA-Z]+
# Extra environment variables to append to this nodeGroup
# This will be appended to the current 'env:' key. You can use any of the kubernetes env
# syntax here
extraEnvs:
- name: "ELASTICSEARCH_USERNAME"
valueFrom:
secretKeyRef:
key: username
- name: "ELASTICSEARCH_PASSWORD"
valueFrom:
secretKeyRef:
key: password
# Allows you to load environment variables from kubernetes secret or config map
envFrom: []
# - secretRef:
# name: env-secret
# - configMapRef:
# name: config-map
# Add sensitive data to k8s secrets
secrets: []
# - name: "env"
# value:
# ELASTICSEARCH_PASSWORD: "LS1CRUdJTiBgUFJJVkFURSB"
# api_key: ui2CsdUadTiBasRJRkl9tvNnw
# - name: "tls"
# value:
# ca.crt: |
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# cert.crt: "LS0tLS1CRUdJTiBlRJRklDQVRFLS0tLS0K"
# cert.key.filepath: "secrets.crt" # The path to file should be relative to the `values.yaml` file.
# A list of secrets and their paths to mount inside the pod
secretMounts: []
# - name: elasticsearch-master-certs
# secretName: elasticsearch-master-certs
# path: /usr/share/logstash/certs/
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
image: "docker.elastic.co/logstash/logstash"
imageTag: "8.5.1"
imagePullPolicy: "IfNotPresent"
imagePullSecrets: []
podAnnotations: {}
# additionals labels
labels: {}
logstashJavaOpts: "-Xmx1g -Xms1g"
resources:
limits:
cpu: "1000m"
memory: "1536Mi"
volumeClaimTemplate:
accessModes: ["ReadWriteOnce"]
resources:
requests:
storage: 1Gi
rbac:
create: false
serviceAccountAnnotations: {}
serviceAccountName: ""
annotations:
#annotation1: "value1"
#annotation2: "value2"
#annotation3: "value3"
podSecurityPolicy:
create: false
spec:
privileged: false
fsGroup:
rule: RunAsAny
runAsUser:
rule: RunAsAny
seLinux:
rule: RunAsAny
supplementalGroups:
rule: RunAsAny
volumes:
- secret
- configMap
- persistentVolumeClaim
persistence:
enabled: false
annotations: {}
extraVolumes:
# - name: extras
# emptyDir: {}
extraVolumeMounts:
# - name: extras
# mountPath: /usr/share/extras
# readOnly: true
extraContainers:
# - name: do-something
# image: busybox
# command: ['do', 'something']
extraInitContainers:
# image: busybox
# This is the PriorityClass settings as defined in
# https://kubernetes.io/docs/concepts/configuration/pod-priority-preemption/#priorityclass
priorityClassName: ""
# By default this will make sure two pods don't end up on the same node
# Changing this to a region would allow you to spread pods across regions
antiAffinityTopologyKey: "kubernetes.io/hostname"
# Hard means that by default pods will only be scheduled if there are enough nodes for them
# and that they will never end up on the same node. Setting this to soft will do this "best effort"
antiAffinity: "hard"
# This is the node affinity settings as defined in
# https://kubernetes.io/docs/concepts/scheduling-eviction/assign-pod-node/#node-affinity
nodeAffinity: {}
# This is inter-pod affinity settings as defined in
# https://kubernetes.io/docs/concepts/scheduling-eviction/assign-pod-node/#inter-pod-affinity-and-anti-affinity
podAffinity: {}
# The default is to deploy all pods serially. By setting this to parallel all pods are started at
# the same time when bootstrapping the cluster
podManagementPolicy: "Parallel"
httpPort: 9600
# Custom ports to add to logstash
extraPorts:
- name: beats
containerPort: 5001
updateStrategy: RollingUpdate
# This is the max unavailable setting for the pod disruption budget
# The default value of 1 will make sure that kubernetes won't allow more than 1
# of your pods to be unavailable during maintenance
maxUnavailable: 1
podSecurityContext:
fsGroup: 1000
runAsUser: 1000
securityContext:
capabilities:
drop:
- ALL
# readOnlyRootFilesystem: true
runAsNonRoot: true
runAsUser: 1000
# How long to wait for logstash to stop gracefully
terminationGracePeriod: 120
# Probes
# Default probes are using `httpGet` which requires that `http.host: 0.0.0.0` is part of
# `logstash.yml`. If needed probes can be disabled or overridden using the following syntaxes:
# disable livenessProbe
# livenessProbe: null
# replace httpGet default readinessProbe by some exec probe
# readinessProbe:
# httpGet: null
# exec:
# command:
# - curl
# - localhost:9600
livenessProbe:
httpGet:
path: /
port: http
initialDelaySeconds: 300
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 3
successThreshold: 1
readinessProbe:
httpGet:
path: /
port: http
initialDelaySeconds: 60
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 3
successThreshold: 3
## Use an alternate scheduler.
## ref: https://kubernetes.io/docs/tasks/administer-cluster/configure-multiple-schedulers/
schedulerName: ""
nodeSelector: {}
tolerations: []
nameOverride: ""
fullnameOverride: ""
lifecycle:
# preStop:
# exec:
# command: ["/bin/sh", "-c", "echo Hello from the postStart handler > /usr/share/message"]
# postStart:
# exec:
service:
annotations: {}
type: ClusterIP
loadBalancerIP: ""
ports:
- name: beats
port: 5044
protocol: TCP
targetPort: 5044
- name: http
port: 8080
protocol: TCP
targetPort: 8080
ingress:
enabled: false
annotations:
# kubernetes.io/tls-acme: "true"
className: "nginx"
pathtype: ImplementationSpecific
hosts:
- host: logstash-example.local
paths:
- path: /beats
servicePort: 5044
- path: /http
servicePort: 8080
tls: []
# - secretName: logstash-example-tls
# hosts:
# - logstash-example.local
Can you please give proper steps for this...Like my filebeats needs to be my input for logstash.?
That does not look correct, not correct syntax where is the closing brace }
You probably need to share the rest of the configuration (elasticsearch etc) as well so we can see what the value should be
This is filebeat 8.5.1 for an input to logstash
replicas: 1
logstashConfig: {}
# logstash.yml: |
# key:
# nestedkey: value
# key = value
logstashPipeline:
logstash.conf: |
beats {
port => 5044
ssl => true
logstashPattern: {}
# pattern.conf: |
# syntax here
extraEnvs:
valueFrom:
secretKeyRef:
key: username
valueFrom:
secretKeyRef:
key: password
envFrom: []
# - secretRef:
# name: env-secret
# - configMapRef:
# name: config-map
secrets: []
# - name: "env"
# value:
# - name: "tls"
# value:
# ca.crt: |
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
secretMounts:
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
imageTag: "8.5.1"
podAnnotations: {}
labels: {}
resources:
limits:
cpu: "1000m"
memory: "1536Mi"
resources:
requests:
storage: 1Gi
rbac:
create: false
annotations:
podSecurityPolicy:
create: false
spec:
privileged: false
fsGroup:
rule: RunAsAny
runAsUser:
rule: RunAsAny
seLinux:
rule: RunAsAny
supplementalGroups:
rule: RunAsAny
volumes:
- secret
- configMap
persistence:
enabled: false
annotations: {}
extraVolumes:
# - name: extras
# emptyDir: {}
extraVolumeMounts:
# - name: extras
# readOnly: true
extraContainers:
# image: busybox
# image: busybox
nodeAffinity: {}
podAffinity: {}
httpPort: 9600
extraPorts:
- name: beats
containerPort: 5001
maxUnavailable: 1
podSecurityContext:
fsGroup: 1000
runAsUser: 1000
securityContext:
capabilities:
drop:
- ALL
runAsNonRoot: true
runAsUser: 1000
# Probes
# readinessProbe:
# httpGet: null
# exec:
# command:
# - curl
# - localhost:9600
livenessProbe:
httpGet:
path: /
port: http
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 3
successThreshold: 1
readinessProbe:
httpGet:
path: /
port: http
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 3
successThreshold: 3
schedulerName: ""
nodeSelector: {}
tolerations: []
nameOverride: ""
lifecycle:
# preStop:
# exec:
# postStart:
# exec:
service:
annotations: {}
type: ClusterIP
loadBalancerIP: ""
ports:
- name: beats
port: 5044
protocol: TCP
targetPort: 5044
- name: http
port: 8080
protocol: TCP
targetPort: 8080
ingress:
enabled: false
annotations:
className: "nginx"
hosts:
paths:
- path: /beats
servicePort: 5044
- path: /http
servicePort: 8080
tls: []
# hosts:
This is elasticsearch 8.5.1
clusterName: "elasticsearch"
nodeGroup: "master"
# The service that non master groups will try to connect to when joining the cluster
# This should be set to clusterName + "-" + nodeGroup for your master group
masterService: ""
# Elasticsearch roles that will be applied to this nodeGroup
# These will be set as environment variables. E.g. node.roles=master
# https://www.elastic.co/guide/en/elasticsearch/reference/current/modules-node.html#node-roles
roles:
- master
- data
- data_content
- data_hot
- data_warm
- data_cold
- ingest
- ml
- remote_cluster_client
- transform
replicas: 1
minimumMasterNodes: 1
esMajorVersion: ""
# Allows you to add any config files in /usr/share/elasticsearch/config/
# such as elasticsearch.yml and log4j2.properties
esConfig: {}
# elasticsearch.yml: |
# key:
# nestedkey: value
# key = value
createCert: true
esJvmOptions: {}
# processors.options: |
# -XX:ActiveProcessorCount=3
# syntax here
extraEnvs: []
# - name: MY_ENVIRONMENT_VAR
# value: the_value_goes_here
envFrom: []
# - secretRef:
# name: env-secret
# - configMapRef:
# name: config-map
# Disable it to use your own elastic-credential Secret.
secret:
enabled: true
password: "" # generated randomly if not defined
# This is useful for mounting certificates for security and for mounting
# the X-Pack license
secretMounts: []
# - name: elastic-certificates
# secretName: elastic-certificates
# path: /usr/share/elasticsearch/config/certs
# defaultMode: 0755
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
image: "docker.elastic.co/elasticsearch/elasticsearch"
imageTag: "8.5.1"
podAnnotations: {}
# iam.amazonaws.com/role: es-cluster
labels: {}
esJavaOpts: "" # example: "-Xmx1g -Xms1g"
resources:
limits:
cpu: "1000m"
memory: "2Gi"
initResources: {}
# limits:
# cpu: "25m"
# # memory: "128Mi"
# requests:
# cpu: "25m"
# memory: "128Mi"
networkHost: "0.0.0.0"
resources:
requests:
storage: 5Gi
rbac:
create: false
automountToken: true
podSecurityPolicy:
create: false
spec:
privileged: true
fsGroup:
rule: RunAsAny
runAsUser:
rule: RunAsAny
seLinux:
rule: RunAsAny
supplementalGroups:
rule: RunAsAny
volumes:
- secret
- configMap
- emptyDir
persistence:
enabled: true
labels:
# Add default labels for the volumeClaimTemplate of the StatefulSet
enabled: false
annotations: {}
extraVolumes: []
# - name: extras
# emptyDir: {}
extraVolumeMounts: []
# - name: extras
# readOnly: true
extraContainers: []
# image: busybox
extraInitContainers: []
# image: busybox
antiAffinity: "soft"
# https://kubernetes.io/docs/concepts/configuration/assign-pod-node/#node-affinity-beta-feature
nodeAffinity: {}
# The environment variables injected by service links are not used, but can lead to slow Elasticsearch boot times when
# there are many services in the current namespace.
# If you experience slow pod startups you probably want to set this to `false`.
enableServiceLinks: true
protocol: https
httpPort: 9200
transportPort: 9300
service:
enabled: true
labels: {}
labelsHeadless: {}
type: ClusterIP
# Consider that all endpoints are considered "ready" even if the Pods themselves are not
# https://kubernetes.io/docs/reference/kubernetes-api/service-resources/service-v1/#ServiceSpec
publishNotReadyAddresses: false
nodePort: ""
annotations: {}
httpPortName: http
transportPortName: transport
loadBalancerIP: ""
loadBalancerSourceRanges: []
externalTrafficPolicy: ""
maxUnavailable: 1
podSecurityContext:
fsGroup: 1000
runAsUser: 1000
securityContext:
capabilities:
drop:
- ALL
runAsNonRoot: true
runAsUser: 1000
# How long to wait for elasticsearch to stop gracefully
sysctlVmMaxMapCount: 262144
readinessProbe:
failureThreshold: 3
initialDelaySeconds: 10
periodSeconds: 10
successThreshold: 3
timeoutSeconds: 5
# https://www.elastic.co/guide/en/elasticsearch/reference/current/cluster-health.html#request-params wait_for_status
clusterHealthCheckParams: "wait_for_status=green&timeout=1s"
schedulerName: ""
nodeSelector: {}
tolerations: []
# Enabling this will publicly expose your Elasticsearch instance.
# Only enable this if you have security enabled on your cluster
ingress:
enabled: false
annotations: {}
# kubernetes.io/ingress.class: nginx
className: "nginx"
hosts:
- host: chart-example.local
paths:
- path: /
tls: []
# - secretName: chart-example-tls
# hosts:
# - chart-example.local
nameOverride: ""
healthNameOverride: ""
lifecycle: {}
# preStop:
# exec:
# postStart:
# exec:
# command:
# - bash
# - -c
# #!/bin/bash
# # Add a template to adjust number of shards/replicas
# TEMPLATE_NAME=my_template
# INDEX_PATTERN="logstash-*"
# SHARD_COUNT=8
# REPLICA_COUNT=1
# ES_URL=http://localhost:9200
# while [[ "$(curl -s -o /dev/null -w '%{http_code}\n' $ES_URL)" != "200" ]]; do sleep 1; done
# curl -XPUT "$ES_URL/_template/$TEMPLATE_NAME" -H 'Content-Type: application/json' -d'{"index_patterns":['\""$INDEX_PATTERN"\"'],"settings":{"number_of_shards":'$SHARD_COUNT',"number_of_replicas":'$REPLICA_COUNT'}}'
sysctlInitContainer:
enabled: true
keystore: []
networkPolicy:
## Enable creation of NetworkPolicy resources. Only Ingress traffic is filtered for now.
## In order for a Pod to access Elasticsearch, it needs to have the following label:
## {{ template "uname" . }}-client: "true"
## Example for default configuration to access HTTP port:
## elasticsearch-master-http-client: "true"
## Example for default configuration to access transport port:
## elasticsearch-master-transport-client: "true"
http:
enabled: false
## if explicitNamespacesSelector is not set or set to {}, only client Pods being in the networkPolicy's namespace
## and matching all criteria can reach the DB.
## But sometimes, we want the Pods to be accessible to clients from other namespaces, in this case, we can use this
## parameter to select these namespaces
# explicitNamespacesSelector:
# # Accept from namespaces with all those different rules (only from whitelisted Pods)
# matchLabels:
# role: frontend
# matchExpressions:
# - {key: role, operator: In, values: [frontend]}
## Additional NetworkPolicy Ingress "from" rules to set. Note that all rules are OR-ed.
# additionalRules:
# - podSelector:
# matchLabels:
# role: frontend
# - podSelector:
# matchExpressions:
# - key: role
# operator: In
# values:
# - frontend
transport:
## Note that all Elasticsearch Pods can talk to themselves using transport port even if enabled.
enabled: false
# matchLabels:
# role: frontend
# matchExpressions:
# additionalRules:
# - podSelector:
# matchLabels:
# role: frontend
# - podSelector:
# matchExpressions:
# - key: role
# operator: In
# values:
# - frontend
tests:
enabled: true
Hey bro, Actually the communication is alright between logstash and elasticsearch is working fine. Then I've install metricbeat in the same cluster. And I couldn't find metric beat in the kibana, do i want to change any configuration in kibana 8.5.1v
elasticsearchHosts: "https://elasticsearch-master:9200"
elasticsearchCertificateSecret: elasticsearch-master-certs
elasticsearchCertificateAuthoritiesFile: ca.crt
elasticsearchCredentialSecret: elasticsearch-master-credentials
replicas: 1
# syntax here
extraEnvs: []
# - name: "NODE_OPTIONS"
# value: "--max-old-space-size=1800"
envFrom: []
# - secretRef:
# name: env-secret
# - configMapRef:
# name: config-map
secretMounts: []
# - name: kibana-keystore
# secretName: kibana-keystore
# path: /usr/share/kibana/data/kibana.keystore
# subPath: kibana.keystore # optional
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
image: "docker.elastic.co/kibana/kibana"
imageTag: "8.5.1"
labels: {}
annotations: {}
podAnnotations: {}
resources:
requests:
limits:
cpu: "1000m"
memory: "2Gi"
protocol: http
serverHost: "0.0.0.0"
healthCheckPath: "/app/kibana"
# Allows you to add any config files in /usr/share/kibana/config/
# such as kibana.yml
kibanaConfig: {}
# kibana.yml: |
# key:
# nestedkey: value
# If Pod Security Policy in use it may be required to specify security context as well as service account
podSecurityContext:
fsGroup: 1000
securityContext:
capabilities:
drop:
- ALL
runAsNonRoot: true
runAsUser: 1000
serviceAccount: ""
# Whether or not to automount the service account token in the pod. Normally, Kibana does not need this
httpPort: 5601
extraVolumes:
# - name: extras
# emptyDir: {}
extraVolumeMounts:
# - name: extras
# readOnly: true
extraContainers: []
# - name: dummy-init
# image: busybox
# command: ['echo', 'hey']
# image: busybox
updateStrategy:
type: "Recreate"
service:
type: ClusterIP
loadBalancerIP: ""
port: 5601
nodePort: ""
labels: {}
annotations: {}
# cloud.google.com/load-balancer-type: "Internal"
# service.beta.kubernetes.io/aws-load-balancer-internal: 0.0.0.0/0
# service.beta.kubernetes.io/azure-load-balancer-internal: "true"
# service.beta.kubernetes.io/openstack-internal-load-balancer: "true"
# service.beta.kubernetes.io/cce-load-balancer-internal-vpc: "true"
# 0.0.0.0/0
httpPortName: http
ingress:
enabled: false
className: "nginx"
annotations: {}
hosts:
- host: kibana-example.local
paths:
- path: /
#tls: []
# hosts:
readinessProbe:
failureThreshold: 3
periodSeconds: 10
successThreshold: 3
timeoutSeconds: 5
nodeSelector: {}
tolerations: []
affinity: {}
nameOverride: ""
lifecycle: {}
# preStop:
# exec:
# postStart:
# exec:
daemonset:
# Annotations to apply to the daemonset
annotations: {}
labels: {}
affinity: {}
# Include the daemonset
enabled: true
# Extra environment variables for Metricbeat container.
envFrom: []
# - configMapRef:
# name: config-secret
extraEnvs:
valueFrom:
secretKeyRef:
key: username
valueFrom:
secretKeyRef:
key: password
extraVolumes: []
# - name: extras
# emptyDir: {}
# - name: extras
# readOnly: true
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
hostNetworking: false
# Allows you to add any config files in /usr/share/metricbeat
# such as metricbeat.yml for daemonset
metricbeatConfig:
metricbeat.yml: |
metricbeat.modules:
- module: kubernetes
metricsets:
- container
- node
- pod
- system
- volume
period: 10s
host: "${NODE_NAME}"
hosts: ["https://${NODE_NAME}:10250"]
bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
ssl.verification_mode: "none"
# If using Red Hat OpenShift remove ssl.verification_mode entry and
# uncomment these settings:
#ssl.certificate_authorities:
#- /var/run/secrets/kubernetes.io/serviceaccount/service-ca.crt
processors:
- add_kubernetes_metadata: ~
enabled: true
metricsets:
- event
- module: system
period: 10s
metricsets:
- cpu
- load
- memory
- network
- process
- process_summary
processes: ['.*']
process.include_top_n:
by_cpu: 5
by_memory: 5
- module: system
period: 1m
metricsets:
- filesystem
- fsstat
processors:
- drop_event.when.regexp:
system.filesystem.mount_point: '^/(sys|cgroup|proc|dev|etc|host|lib)($|/)'
output.elasticsearch:
hosts: '["https://${ELASTICSEARCH_HOSTS:elasticsearch-master:9200}"]'
ssl.enabled: true
ssl.certificate_authorities: ["/usr/share/metricbeat/certs/ca.crt"]
username: '${ELASTICSEARCH_USERNAME}'
password: '${ELASTICSEARCH_PASSWORD}'
nodeSelector: {}
# This is useful for mounting certificates for security other sensitive values
secretMounts:
path: /usr/share/metricbeat/certs/
# - name: metricbeat-certificates
# secretName: metricbeat-certificates
# path: /usr/share/metricbeat/certs
# Various pod security context settings. Bear in mind that many of these have an impact on metricbeat functioning properly.
# - Filesystem group for the metricbeat user. The official elastic docker images always have an id of 1000.
# - User that the container will execute as. Typically necessary to run as root (0) in order to properly collect host container logs.
# - Whether to execute the metricbeat containers as privileged containers. Typically not necessarily unless running within environments such as OpenShift.
securityContext:
runAsUser: 0
privileged: false
resources:
requests:
cpu: "100m"
memory: "100Mi"
limits:
cpu: "1000m"
memory: "200Mi"
tolerations: []
deployment:
# Annotations to apply to the deployment
annotations: {}
labels: {}
affinity: {}
# Include the deployment
enabled: true
envFrom: []
# - configMapRef:
extraEnvs:
valueFrom:
secretKeyRef:
key: username
valueFrom:
secretKeyRef:
key: password
extraVolumes: []
# - name: extras
# emptyDir: {}
# - name: extras
# readOnly: true
# such as metricbeat.yml for deployment
hostAliases: []
#- ip: "127.0.0.1"
# hostnames:
# - "foo.local"
# - "bar.local"
metricbeatConfig:
metricbeat.yml: |
metricbeat.modules:
enabled: true
metricsets:
- state_node
- state_deployment
- state_replicaset
- state_pod
- state_container
period: 10s
hosts: ["${KUBE_STATE_METRICS_HOSTS}"]
ssl.enabled: true
nodeSelector: {}
secretMounts:
securityContext:
runAsUser: 0
privileged: false
resources:
requests:
cpu: "100m"
memory: "100Mi"
limits:
cpu: "1000m"
memory: "200Mi"
tolerations: []
# Replicas being used for the kube-state-metrics metricbeat deployment
replicas: 1
extraContainers: ""
# image: busybox
extraInitContainers: ""
# image: busybox
# Root directory where metricbeat will write data to in order to persist registry data across pod restarts (file position and other metadata).
hostPathRoot: /var/lib
image: "docker.elastic.co/beats/metricbeat"
imageTag: "8.5.1"
livenessProbe:
exec:
command:
- sh
- -c
#!/usr/bin/env bash -e
curl --fail 127.0.0.1:5066
failureThreshold: 3
periodSeconds: 10
timeoutSeconds: 5
readinessProbe:
exec:
command:
- sh
- -c
metricbeat test output
failureThreshold: 3
periodSeconds: 10
timeoutSeconds: 5
# Whether this chart should self-manage its service account, role, and associated role binding.
managedServiceAccount: true
clusterRoleRules:
- apiGroups: [""]
resources:
- nodes
- namespaces
- events
- pods
- services
verbs: ["get", "list", "watch"]
- apiGroups: ["extensions"]
resources:
- replicasets
- apiGroups: ["apps"]
resources:
- statefulsets
- deployments
- replicasets
- apiGroups: [""]
resources:
- nodes/stats
verbs: ["get"]
- apiGroups:
resources:
- nodes/stats
verbs:
- get
- nonResourceURLs:
- "/metrics"
verbs:
- get
podAnnotations: {}
# Custom service account override that the pod will use
serviceAccount: ""
# Annotations to add to the ServiceAccount that is created if the serviceAccount value isn't set.
# eks.amazonaws.com/role-arn: arn:aws:iam::111111111111:role/k8s.clustername.namespace.serviceaccount
# How long to wait for metricbeat pods to stop gracefully
terminationGracePeriod: 30
# Override various naming aspects of this chart
# Only edit these if you know what you're doing
nameOverride: ""
kube_state_metrics:
enabled: true
# host is used only when kube_state_metrics.enabled: false
host: ""
secrets: []
# - name: "env"
# value:
# - name: "tls"
# value:
# ca.crt: |
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# LS0tLS1CRUdJT0K
# DEPRECATED
# such as metricbeat.yml for both daemonset and deployment
metricbeatConfig: {}
Please edit your post and format your code with </> so it is readable.
Unfortunately as I said ... I am not an expert with helm
Have you read this
This is about setup....
Also I suggest you look at the metricbeat logs and look for issues.. if you find errors you can post them here.
I assume you are using our official helm repos.
I am more familiar with directly applying a manifest with kubectl
Thanks man...I'll look into it..
@Ram_M It may be worth looking at 1ClickECK: GitHub - sunileman/1ClickECK: 1Click Automation of Elastic Cloud on Kubernetes. It deploys AWS EKS, Azure AKS, and/or GCP GKE along with ECK ES and logstash. Deploys with ease. you can then bring additional k8s manifest against the deployed asset.
Thanks...
@Ram_M I highly recommend what @Sunile_Manjee Referred you two... he is a Jedi of this stuff... he wrote 1ClickECK!
Great...
