Need help for using wildcard query
Hi All,
We are using Java API of elasticsearch(0.19.1) for our application. I want
to store a document field with value "1-d:3.4.5" and then want to search
for the document having the value of the field "starts with 1 and end with
4.5". I tried to use WildcardQueryBuilder as follows
WildcardQueryBuilder wildcardQuery = QueryBuilders.wildcardQuery(, "1*4.5");
It is not able to retrieve any document. Can any one suggest me how to
achieve the same.
Thank you in advance.
Best,
Ashutosh Bhattacharya
Stammstr. 39
50823 Köln, Deutschland
Mob : (0049) 0176 31242825
Email: ashutosh.bhattacharya.in@gmail.com
maybe your field is being analyzed into multiple terms? you can use the
analyzehttp://www.elasticsearch.org/guide/reference/api/admin-indices-analyze.htmlendpoint to check.
On Monday, June 4, 2012 10:13:33 AM UTC-4, Ashutosh Bhattacharya wrote:
Hi All,
achieve the same.
Best,
Stammstr. 39
