Hi Jorg,
Thanks for quick reply. I tried the bracket notation from the river
query itself .I tried the following query and got the result.
" SELECT GenericDescription,GenericId,GroupNo,ListofDescriptionIDs AS
ListofDescriptionIDs[] FROM temp"
it worked for me for list of descriptionIDs it is created as array.
"_index": "test",
"_type": "testv1",
"_id": "uYTwn2iBSKGBPt0Auz834w",
"_score": 1,
"_source": {
"GenericDescription": "test",
"GenericId": "1",
"GroupNo": "35",
"ListofDescriptionIDs": [
"10",
"20",
"61",
"71",
"73",
"74",
"77",
"110",
"116"
the mapping directly created by river itself in es server. the type
for ListofDescriptionIDs created as "string".but it is taking data as
arrays from query. is this "string " is correct for the
ListofDescriptionIDs field. eventhough we declared as string how ES
consider as array for this field?
Thanks,
phani.
On Monday, October 6, 2014 7:25:26 PM UTC+5:30, Jörg Prante wrote:
The mail is hard to read, the layout is scrambled.
For simple integer array, you do not need type "nested".
What is the SQL statement you tried for JDBC river? You have seen the
examples for bracket notation?
Jörg
On Mon, Oct 6, 2014 at 2:04 PM, <phani.n...@goktree.com <javascript:>>
wrote:
Hi All,
I have a scenario like, I need to build an index with four fields
(Generic Description,GenericId ,GroupNo, List of Catalogsids ).
Here is sample example of mysql table.
Generic Description GenericId GroupNo
List of Catalogsids FrameKit
1 35 10,20,24,56,78,90,87 Pulley 3480 23 36 Bypass Pulley
4133 7 55
The fourth column in above table field contains multiple values for one
row. Now i want to create index using above mysql table via river
concept so that fourth column in the table sholud be represented as array
in Elasticsearch i tried this concept but i am not getting a good way to
solve this.please help me in this.
Mapping i used:
PUT /temp
"mappings": {
"tempv1" : {
"properties" : {
"GenericDescription" : {"type" : "string"},
"GenericId" : {"type" : "string"},
"GroupNo" : {"type" : "string"},
"descriptionids" : {
"type" : "nested",
"properties" : {
"ListofDescriptionIDs" : {"type" : "integer"}
Thanks in advance.
phani srinivas
"elasticsearch" group.
To view this discussion on the web visit
https://groups.google.com/d/msgid/elasticsearch/c81e61d2-c73d-42f9-82ac-86ced59f7316%40googlegroups.com
https://groups.google.com/d/msgid/elasticsearch/c81e61d2-c73d-42f9-82ac-86ced59f7316%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/9d1abbe3-d63d-435c-8a48-44b6bfb11144%40googlegroups.com.
