Need help to configure http output plugin for https
Hello i would like to send data via http output plugin (Http output plugin | Logstash Reference [8.19] | Elastic) to a https url . I have a very simple example with "https://www.google.com" which is not working is it possible to know what's the problem ?
http {
url => "https://www.google.fr"
http_method => "get"
for debug
stdout {}
I have the following output from logstash
[2022-06-09T11:02:47,803][ERROR][logstash.outputs.http ][main][4811562b3a9d0e71e85ecd54b9b911ea920186a034823835f8843588f7bcb611] Encountered non-2xx HTTP code 400 {:response_code=>400, :url=>"https://www.google.fr", :event=>#LogStash::Event:0x7470b923}
Ok I identified my problem which is not due to https but due to the fact i use the get method which always pass a body in the plugin implementation. Our output endpoint answer 400 when body is sent on get method (a querystring is wanted)
