Need help with setting up 1 masternode and two datanodes set up
Hello All,
As we are implementing ELK in our org as a pilot project, I'm trying to set up 3 nodes Elastic cluster (all acts master and data nodes ), I have created Ubuntu servers in Azure cloud with specific hardware configs. I just stuck at configuring the "Elasticsearch.yml" file on the master node(10.208.xx.xx), here, I'd mainly like to know the configs which I need to change in the .yml file
    Elasticsearch.yml on Masternode
        `Preformatted text`# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
cluster.name: elastic-dev
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
node.name: node-1
node.master: true
node.data: true
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
path.data: /var/lib/elasticsearch
# Path to log files:
path.logs: /var/log/elasticsearch
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
network.host: 10.208.xx.xx
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
discovery.seed_hosts: ["10.208.xx.xx", "10.208.yy.yy"]
# Bootstrap the cluster using an initial set of master-eligible nodes:
cluster.initial_master_nodes: ["10.208.xx.xx", "10.208.yy.yy"]
discovery.zen.minimum_master_nodes: 2
#discovery.zen.ping.unicast.hosts: ["10.208.xx.xx", "10.208.yy.yy"]
# For more information, consult the discovery and cluster formation module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
xpack.security.enabled: true
xpack.security.transport.ssl.enabled: true
xpack.security.http.ssl.enabled: true
xpack.security.http.ssl.key: instance/instance.key
xpack.security.http.ssl.certificate: instance/instance.crt
xpack.security.http.ssl.certificate_authorities: ca/ca.crt
xpack.security.transport.ssl.key: instance/instance.key
xpack.security.transport.ssl.certificate: instance/instance.crt
xpack.security.transport.ssl.certificate_authorities: ca/ca.crt
#xpack.security.transport.ssl.keystore.path: elastic-certificates.p12
#xpack.security.transport.ssl.truststore.path: elastic-certificates.p12
#xpack.security.authc.api_key.enabled: true
# This turns on SSL for the HTTP (Rest) interface
#xpack.security.http.ssl.enabled: true
#xpack.security.http.ssl.keystore.path: "http.p12"
#elasticsearch.ssl.certificateAuthorities: "ca.p12"
"Elasticsearch.yml on data node"
node.name: node-2
node.master: true
node.data: true
#node.attr.rack: r1
# limit.
network.host: 10.208.yy.yy
#http.port: 9200
#elasticsearch.ssl.certificateAuthorities: "ca.p12" `
Note1: I have added ca cert, instance cert on data node as well similar to mater node
Note2: When i did curl it says "Empty reply from server"(curl -k -l 10.208.xx.xx:9200>
My data node is also not showing as it connected with cluster when I did
"GET _cluster/health?pretty" from Kibana UI
Please let me know any changes need to be done
TIA
Uncomment the port and make sure the firewall ports are open on the VM. 9200/TCP. "Often forgot" on all nodes.
All 3 nodes will be data nodes in your setup which is a good thing btw. In your 3 node setup you don't need to directly call out master and data roles. Comment those lines out. Your setup is not using a coordinating node. Comment out discovery.zen.minium.master_nodes. I'm guessing this is not a licensed cluster and it will default to 1 master on the basic unless something changed recently.
  1. checked firewall on all nodes (sudo firewall-cmd --list-ports <o/p : 9200/TCP)
  2. commented node.master,node.data in both .yml files and also discovery.zen.minium.master_nodes)
  3. From /var/log/ , i could see this is a "basic" license
After restarting the service,
on Node1:
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
        at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:714) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
		at io.netty.channel.nio.NioEventLoop.processSelectedKeysPlain(NioEventLoop.java:615) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
		at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:578) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
		at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493) [netty-transport-4.1.49.Final.jar:4.1.49.Final]
   at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989) [netty-common-4.1.49.Final.jar:4.1.49.Final]
   at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [netty-common-4.1.49.Final.jar:4.1.49.Final]
    at java.lang.Thread.run(Thread.java:832) [?:?]
[2020-10-14T14:59:22,832][INFO ][o.e.c.r.a.AllocationService] [node-1] Cluster health status changed from [RED] to [YELLOW] (reason: [shards started
[[ilm-history-2-000001][0], [logstash-2020.09.22-000001][0]]]).
On Node2:
      tail -f /var/log/elasticsearch/elastic-dev.log
    [2020-10-14T14:57:52,469][TRACE][o.e.d.PeerFinder         ] [node-2] deactivating and setting leader to {node-2}{L9s_NdEjRY-XXXXXXXXXXX}{f731TrXXXXXXXXXXXXXXXXX}{10.208.yy.yy}{10.208.yy.yy:9300}{dilmrt}{ml.machine_memory=16791863296, xpack.installed=true, transform.node=true, ml.max_open_jobs=20}
    [2020-10-14T14:57:52,470][TRACE][o.e.d.PeerFinder         ] [node-2] not active
    [2020-10-14T14:57:52,483][INFO ][o.e.c.s.MasterService    ] [node-2] elected-as-master
    ([1] nodes joined)[{node-2}{L9s_NdEjRY-XXXXXXXXXXX}{f731TrXXXXXXXXXXXXXXXXX}
    xpack.installed=true, transform.node=true, ml.max_open_jobs=20} elect leader,
    _BECOME_MASTER_TASK_, _FINISH_ELECTION_], term: 31, version: 123, delta: master
`node changed {previous [], current [{node-2}{L9s_NdEjRY-XXXXXXXXXXX}`
    ml.max_open_jobs=20}]}
    [2020-10-14T14:57:52,596][INFO ][o.e.c.s.ClusterApplierService] [node-2] master node
    ml.max_open_jobs=20}]}, term: 31, version: 123, reason: Publication{term=31,
    version=123}
    [2020-10-14T14:57:52,639][INFO ][o.e.h.AbstractHttpServerTransport] [node-2]
    publish_address {10.208.yy.yy:9200}, bound_addresses {10.208.yy.yy:9200}
    [2020-10-14T14:57:52,639][INFO ][o.e.n.Node               ] [node-2] started
    [2020-10-14T14:57:52,842][INFO ][o.e.l.LicenseService     ] [node-2] license [24a9f11a-
    f80e-42b9-97c1-b64c8dc086ee] mode [basic] - valid
    [2020-10-14T14:57:52,843][INFO ][o.e.x.s.s.SecurityStatusChangeListener] [node-2] Active
    license is now [BASIC]; Security is enabled
    [2020-10-14T14:57:52,851][INFO ][o.e.g.GatewayService     ] [node-2] recovered [0]
    indices into cluster_state
    [2020-10-14T14:57:53,300][TRACE][o.e.d.PeerFinder         ] [node-2] not active
The nodes communicate on port 9300, so this need to be open between the nodes, not 9200.
i just opened 9300 on both nodes , did telnet shows "connected"
and when i did
curl http://10.208.yy.yy:9300/_cluster/health?pretty
O/P:
curl: (52) Empty reply from server
Note: "when i disabled Xpack , i got the cluster status in JSON (as expected) "
Add to the yml and see if you get any change.
xpack.security.transport.ssl.verification_mode: certificate
Nothing, still shows same
is it showing same o/p because of X-pack enabled ?
You need to curl on port 9200. But both 9200 and 9300 ports need to be opened.
Infact i opened both ports
$ sudo firewall-cmd --list-ports
9200/tcp 9300/tcp
and applied curl on both ports , still shows same
Did you add ssl?
Yes , i have added SSL , and identified the problem
the new node acts as separate cluster itself with own UUID, have executed below command on this node and it connected with the local cluster
elasticsearch-node detach-cluster
Now i see new data node connected with Master
