Need mapping help with unit test in java api
I have a json mapping file that I user for unit testing that is based
on the one I use with CURL. It looks like the java api only accepts
the "mapping: {}" section that starts with the type like this:
    client.admin()
            .indices()
            .create(createIndexRequest("myIndex")
                .mapping("records", "records:{}")
            .actionGet();
I want to add an edgeNGram tokenizer to a field and it looks like it
needs to be specified as follows:
"settings" : {
"analysis": {
"analyzer": {
"containsText" : {
"tokenizer": "whitespace",
"filter": ["lowercase", "autocomplete"]
"filter": {
"autocomplete": {"type": "edgeNGram", "min_gram": "1",
"max_gram": "50", "side": "front"}
"mappings" : {
"records" : {
"properties" : {
"name":{"type":"string", "analyzer":"containsText"}
This seems to work from the REST api, but the java mapping api gives
the following exception.
org.elasticsearch.index.mapper.MapperParsingException: mapping
[records]
at org.elasticsearch.cluster.metadata.MetaDataCreateIndexService
$1.execute(MetaDataCreateIndexService.java:244)
at org.elasticsearch.cluster.service.InternalClusterService
$2.run(InternalClusterService.java:211)
at java.util.concurrent.ThreadPoolExecutor
$Worker.runTask(ThreadPoolExecutor.java:886)
$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.elasticsearch.index.mapper.MapperParsingException:
Mapping must have the type as the root object
at
org.elasticsearch.index.mapper.DocumentMapperParser.extractMapping(DocumentMapperParser.java:
231)
at
org.elasticsearch.index.mapper.DocumentMapperParser.parse(DocumentMapperParser.java:
141)
at
org.elasticsearch.index.mapper.MapperService.parse(MapperService.java:
269)
at
org.elasticsearch.index.mapper.MapperService.add(MapperService.java:
172)
$1.execute(MetaDataCreateIndexService.java:241)
How can I set this mapping up using the java api so that I can perform
some unit testing with ngrams to make sure they are working
correctly?
Thanks!
  • Craig
Hi Craig,
Not sure it will fit to your needs but I wrote something here that create an
index using settings.
https://github.com/dadoonet/spring-elasticsearch/blob/master/src/main/java/f
r/pilato/spring/elasticsearch/ElasticsearchAbstractClientFactoryBean.java#L6
69
Also, I define new mappings as follow :
09
			PutMappingResponse response =
client.admin().indices()
.preparePutMapping(index)
.setType(type)
.setSource(source)
.execute().actionGet();
Source is a String containing:
"tweet" : {
"properties" : {
"message" : {"type" : "string", "store" : "yes"}
(see
https://github.com/dadoonet/spring-elasticsearch/blob/master/src/test/resour
ces/es1/twitter/tweet.json )
Hope this could help you to solve your issue.
David.
-----Message d'origine-----
De : elasticsearch@googlegroups.com
[mailto:elasticsearch@googlegroups.com] De la part de Craig Brown
Envoyé : jeudi 24 mai 2012 23:36
À : elasticsearch
Objet : Need mapping help with unit test in java api.
on the one I use with CURL. It looks like the java api only accepts the
    client.admin()
            .indices()
            .actionGet();
"settings" : {
"analysis": {
"analyzer": {
"containsText" : {
"filter": {
"mappings" : {
"records" : {
"properties" : {
[records]
at
231)
at
rParser.java:
141)
at
269)
at
172)
some unit testing with ngrams to make sure they are working correctly?
Thanks!
  • Craig
Interesting. You're using a different api than I am to create the
index mapping. I'll need to try that. Thanks for the code resource,
very neat and understandable.
  • Craig
On Thu, May 24, 2012 at 3:47 PM, David Pilato david@pilato.fr wrote:
Hi Craig,
69
09
.setType(type)
.setSource(source)
"tweet" : {
"properties" : {
(see
David.
À : elasticsearch
    client.admin()
            .indices()
            .actionGet();
"settings" : {
"analysis": {
"analyzer": {
"containsText" : {
"filter": {
"mappings" : {
"records" : {
"properties" : {
[records]
at
231)
at
rParser.java:
141)
at
269)
at
172)
Thanks!
  • Craig
CRAIG BROWN
chief architect
youwho, Inc.
www.youwho.com
T: 801.855. 0921
M: 801.913. 0939
Ok, figured it out. I tried this one, but must have had the parameters
wrong. So it looks like there is a section for settings and another
for mappings. The REST call must break those apart automatically.
        client.admin()
                .indices()
                .create(createIndexRequest(index)
                    .settings(settings)
                    .mapping(type, mapping)
                .actionGet();
  • Craig
  • Craig
Hi Craig,
69
09
.setType(type)
.setSource(source)
"tweet" : {
"properties" : {
(see
David.
À : elasticsearch
    client.admin()
            .indices()
            .actionGet();
"settings" : {
"analysis": {
"analyzer": {
"containsText" : {
"filter": {
"mappings" : {
"records" : {
"properties" : {
[records]
at
231)
at
rParser.java:
141)
at
269)
at
172)
Thanks!
  • Craig
CRAIG BROWN
chief architect
youwho, Inc.
www.youwho.com
T: 801.855. 0921
M: 801.913. 0939
CRAIG BROWN
chief architect
youwho, Inc.
www.youwho.com
T: 801.855. 0921
M: 801.913. 0939
