I have been using Elasticsearch for quite a while. In nm use case I have document sets denoted by an ID. These sets have documents that are denoted by IDs as well. There is a default mapping that all sets follow. Only difference is that I can add custom analysers to the mappings such that only Document Set has that, all others will remain as it is. I thought of having a parent-child settings between sets and documents. I came up with the following but I don't think I will be able to solve my issue as every set will need to have a new mapping even though it might be same:
PUT /test_index/
"settings": {
"index.store.type": "default",
"index": {
"number_of_shards": 5,
"number_of_replicas": 1,
"refresh_interval": "60s"
"analysis": {
"filter": {
"porter_stemmer_en_EN": {
"type": "stemmer",
"name": "porter"
"default_stop_name_en_EN": {
"type": "stop",
"name": "_english_"
"snowball_stop_words_en_EN": {
"type": "stop",
"stopwords_path": "snowball.stop"
"smart_stop_words_en_EN": {
"type": "stop",
"stopwords_path": "smart.stop"
"shingle_filter_en_EN": {
"type": "shingle",
"min_shingle_size": "2",
"max_shingle_size": "2",
"output_unigrams": true
Here is the default mapping that I have:
PUT /test_index/document_set/_mapping
"document_set": {
"properties": {
"docset_id": {
"type": "string"
PUT /test_index/document/_mapping
"document": {
"dynamic": "strict",
"_parent": {
"type": "document_set"
"properties": {
"doc_id": {
"type": "string"
"text": {
"type": "multi_field",
"fields": {
"text": {
"type": "string",
"store": true,
"index": "analyzed"
"pdf": {
"type": "attachment",
"store": true,
"index": "analyzed"
Now suppose I create a custom analyzer:
"analyzer": {
"shingle_type": {
"type": "custom",
"filter": [
"porter_stemmer_en_EN",
"smart_stop_words_en_EN",
"shingle_filter_en_EN",
"lowercase"
"tokenizer": "whitespace"
But I want to add it only to some specified document_set so that only that set's documents are analyzed by that ,how will I do it?
Any suggestion is welcomed.
