I have one ILM policy named haproxy-ilm for all haprox logs. There are 4 different indices to which logs from each environment are written, i.e., dev, prestaging, staging, and production.
Below is the configuration of logstash prior to ILM:
#filter.conf
if [app_type] == "haproxy" {
grok {
patterns_dir => ["/etc/logstash/conf.d/patterns/haproxy"]
match => ["message", "%{HAPROXYHTTP}"]
add_field => { "[@metadata][index_prefix]" => "%{env}-%{app_type}" }
#output.conf
if [app_type] == "haproxy" and "_grokparsefailure" not in [tags] {
hosts => ["{{ es_servers }}"]
index => "%{[@metadata][index_prefix]}"
While creating index templates for mapping with ILM policy, I thought I could create one template and have all the index patterns in it, like, "index_patterns": ["dev-haproxy-*", "prestaging-haproxy-*, ... ]. I did it using kibana Index Management.
After this, I could modify logstash output.conf like:
#output.conf
ilm_rollover_alias => "%{[@metadata][index_prefix]}"
ilm_policy => "haproxy-ilm"
Finally, bootstrap indices were created with below command for respective environments:
curl -X PUT "elastmaster.mydomain.net:9200/%3Cdev-haproxy-%7Bnow%2Fd%7D-000001%3E?pretty" -H 'Content-Type: application/json' -d'
"aliases": {
"dev-haproxy": {
"is_write_index": true
When I started pushing logs, I got this error:
illegal_argument_exception: setting [index.lifecycle.rollover_alias] for index [dev-haproxy-2020.07.25-000001] is empty or not defined.
This is why, instead of having just one index template, I had to create 4 index templates for each environment and define their respective index.lifecycle.rollover_alias like:
curl -X PUT "elastmaster.mydomain.net:9200/_template/dev?pretty" -H 'Content-Type: application/json' -d'
"index_patterns": ["dev-haproxy-*"],
"settings": {
"index.lifecycle.name": "haproxy-ilm",
"index.lifecycle.rollover_alias": "dev-haproxy"
Please help me understand how can this be optimised to use only one index template as haproxy is not the only log source. I'll have to create a lot of index templates if I go like this.
