Node settings must not contain any index level setting
[2017-11-29T10:53:34,618][ERROR][o.e.b.Bootstrap ] Exception
java.lang.IllegalArgumentException: node settings must not contain any index level settings
at org.elasticsearch.common.settings.SettingsModule.(SettingsModule.java:132) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.node.Node.(Node.java:343) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.node.Node.(Node.java:242) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Bootstrap$5.(Bootstrap.java:232) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:232) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:350) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:123) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:114) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:67) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:122) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.Command.main(Command.java:88) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) [elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) [elasticsearch-5.4.1.jar:5.4.1]
[2017-11-29T10:53:34,624][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [DataNode1] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: java.lang.IllegalArgumentException: node settings must not contain any index level settings
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:127) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:114) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:67) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:122) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.cli.Command.main(Command.java:88) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) ~[elasticsearch-5.4.1.jar:5.4.1]
Caused by: java.lang.IllegalArgumentException: node settings must not contain any index level settings
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:350) ~[elasticsearch-5.4.1.jar:5.4.1]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:123) ~[elasticsearch-5.4.1.jar:5.4.1]
... 6 more
Check your elasticsearch.yml file and remove settings starting with index.
Thanks, but whether this will affect my index settings configurations ?
It will affect new indices. For this, use index templates.
It won’t change anything on the existing ones.
Okay, since this an new setup there is no existing indexes, so where i can define the indexes template ?
Here: https://www.elastic.co/guide/en/elasticsearch/reference/6.0/indices-templates.html
