I am trying to fetch all data in a field to a canvas in the elastic index, but for some reason I am receiving a weird error
here is the sql query I send SELECT app_code FROM "devops_et*"
But I receive this error
Expression failed with the message: [essql] > Unexpected error from Elasticsearch: [verification_exception] Found 1 problem(s) line 1:8: Unknown column [app_code], did you mean [app_code]?
This error is only specific to this field all other fields works perfectly fine. Does any one know what is the problem?
EDIT: upon inspection of the JSON file it seems that the app_code filed has a dot beside it and highlighted in red. Maybe that is the problem? How can I remove it it doesn't seem that I can delete it
@emad101 that restriction on dots being used as leading or trailing character has been introduced in 5.1.3 with the this bug fix.
Given that it's impossible to add such a leading dot field name in my tests on 7.x and the bug fix above, I'm assuming you are testing SQL on a 6.x or 7.x ES version, but with an index created in 5.x or earlier?
@Andrei_Stefan,
I have actually not added any leading dots on my field names, it was automatically done somehow when pushing data. I am also using the latest version.
If you see the below picture, there is a highlighted red dot in the appcode field in the JSON tab
No This is the only one, when I created the index pattern I added "*", I can query through the other field without errors. Only the appcode field that gives the error.
I may have typed the document id incorrectly, the idea was to get the actual document from ES. Can you copy-paste the id from Kibana's JSON tab and get the document?
