Pattern analyzer does not respect max_token_length
I'm testing with ES 2.3.5. My tests show that the pattern analyzer does not respect the max_token_length value.
First I try the standard analyzer.
POST /_analyze
  "analyzer": "standard",
  "text": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy"
In the result I see the default 255 char max_token_length value applied.
  "tokens": [
      "token": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
      "start_offset": 0,
      "end_offset": 255,
      "type": "<ALPHANUM>",
      "position": 0
      "token": "yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy",
      "start_offset": 255,
      "end_offset": 295,
      "position": 1
I try the same thing with the pattern analyzer.
 POST /_analyze
      "analyzer": "pattern",
The result is one token longer than the 255 character limit.
  "tokens": [
      "token": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy",
      "start_offset": 0,
      "end_offset": 295,
      "type": "word",
      "position": 0
I see similar failure when I explicitly set max_token_length or when I try to use my own pattern analyzers and tokenizers with a max_token_length value.
The big problem I'm trying to solve is some of my not_analyzed data has values of length greater than 32,766 characters. This triggers a Lucene error because I get terms greater than the Lucene max length (as well discussed on Stackoverflow UTF-8 Encoding Longer Than Max). I still want some search and sort capability on these long field values, even if it is not perfect.
Looks like a bug to me. I filed
The setting is documented as defaulting to 255 but we're not splitting there. I took a look at the code and didn't see anything about maximum token length either. I certainly could have missed it because it was only a quick look though.
