When I try to start elasticsearch with bin/elasticsearch -f command on
commandline, Ubuntu gives me exec: 177: : Permission denied. I've also
tried it as root but same. There is no info about that I could'nt find
the solution to fix this
Hiya
You're not providing enough information about what you're doing, or how
you've got elasticsearch installed and configured.
Try this:
wget https://github.com/downloads/elasticsearch/elasticsearch/elasticsearch-0.19.2.tar.gz
tar -xzf elasticsearch-0.19.2.tar.gz
cd elasticsearch-0.19.2/
./bin/elasticsearch -f
That should show elasticsearch starting up.
If it doesn't then gist the output.
If it does, then figure out what is different in your current environment
clint
The exec: 177: : Permission denied error is almost certainly caused by
Java not available on your machine.
Try running java -version.
Karel
On Saturday, April 28, 2012 11:16:32 AM UTC+2, Clinton Gormley wrote:
Hiya
the solution to fix thisYou're not providing enough information about what you're doing, or how
you've got elasticsearch installed and configured.Try this:
wget
./bin/elasticsearch -fThat should show elasticsearch starting up.
clint
