Problem creating dynamic index from filename (filebeat)
i am trying to create index name same as filename from source but it doesn't seem to work, here's my logstash config file :
      beats{
     port=> 5044
     grok {
          match => ["source",".*\\%{GREEDYDATA:app_name}"]
       stdout {
         codec => rubydebug
          hosts => ["localhost:9200"]
      index => "%{app_name}"
What do you see on stdout and what makes you think it is not working?
the index name i get is exactly %{app_name}
OK, so there is no [app_name] field on the event.
there is actually! and i also tried many fields that 100% exist but still it doesn't work
here's the pattern test:
pattern
I've found the solution, i have used [log][file][path] instead of source and i used mutate to transform it to lowercase, now it's creating indexes based on the source filename.
