I'm trying to add two range facets, the options in both of them are the same but it's for different filters.
something like this:
const installs = {
type: 'range',
ranges: [
{ from: 0, to: 101, name: '<= 100' },
{ from: 100, to: 501, name: '100 - 500' },
{ from: 500, to: 1001, name: '500 - 1000' },
{ from: 1001, to: 5001, name: '5k' },
{ from: 5001, to: 10001, name: '10k' },
{ from: 10001, to: 50001, name: '50k' },
{ from: 50001, to: 100001, name: '100k' },
{ from: 100001, to: 500001, name: '500k' },
{ from: 500001, to: 1000001, name: '1M' },
{ from: 1000001, to: 10000001, name: '10M' },
{ from: 10000001, to: 100000001, name: '100M' },
{ from: 100000001, name: '> 100M' },
const reviews = {
type: 'range',
ranges: [
And it will look like this in the browser:
The problem is that when I check one of the check-boxes, let's say the option named "<= 100" in "installs" facet, the other "<= 100" checkbox in "reviews" facet is also get selected.
If i changed the "name" value in the above code to different values for each facet it works fine (for example in installs facet it will be "<= 100" & in reviews facet it will be "<= 100 reviews")
Is there is any solution for this? can't we simply add 2 range filters with the same options names ?
