Problem in difference between two dates
Hello ,
I have problem with this script :
if ( doc['entities.status'].value == doc['entities.statusesInformation.statusName'].value ) {
return doc['entities.executionDate'].date - doc['entities.creationDate'].date ;
When i execute it, i got this error :
lang":"painless","caused_by":{"type":"class_cast_exception","reason":"Cannot apply [-] operation to types [org.joda.time.MutableDateTime] and [org.joda.time.MutableDateTime]."}}}]},"status":500}
Thank you for your helps.
As the error states, you can use that operator on the date.
Here are supported date functions: https://www.elastic.co/guide/en/elasticsearch/reference/6.2/modules-scripting-expression.html#_date_field_api
Thank you for your reply.
I solved the problem with date in painless but i have another error ( null pointer exception ) with this :
