Java HotSpot(TM) 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
Exception in thread "main" 2019-08-28 10:44:46,645 main ERROR No Log4j 2 configuration file found. Using default configuration (logging only errors to the console), or user programmatically provided configurations. Set system property 'log4j2.debug' to show Log4j 2 internal initialization logging. See https://logging.apache.org/log4j/2.x/manual/configuration.html for instructions on how to configure Log4j 2
SettingsException[Failed to load settings from [elasticsearch.yml]]; nested: MarkedYAMLException[while scanning for the next token
found character '\t(TAB)' that cannot start any token. (Do not use \t(TAB) for indentation)
in 'reader', line 89, column 1:
at [Source: sun.nio.ch.ChannelInputStream@ab7395e; line: 37, column: 45]]; nested: ScannerException[while scanning for the next token
at org.elasticsearch.common.settings.Settings$Builder.loadFromStream(Settings.java:1097)
at org.elasticsearch.common.settings.Settings$Builder.loadFromPath(Settings.java:1070)
at org.elasticsearch.node.InternalSettingsPreparer.prepareEnvironment(InternalSettingsPreparer.java:83)
at org.elasticsearch.cli.EnvironmentAwareCommand.createEnv(EnvironmentAwareCommand.java:95)
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:86)
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:124)
at org.elasticsearch.cli.Command.main(Command.java:90)
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:115)
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:92)
Caused by: com.fasterxml.jackson.dataformat.yaml.snakeyaml.error.MarkedYAMLException: while scanning for the next token
at com.fasterxml.jackson.dataformat.yaml.snakeyaml.error.MarkedYAMLException.from(MarkedYAMLException.java:27)
at com.fasterxml.jackson.dataformat.yaml.YAMLParser.nextToken(YAMLParser.java:343)
at org.elasticsearch.common.xcontent.json.JsonXContentParser.nextToken(JsonXContentParser.java:52)
at org.elasticsearch.common.settings.Settings.fromXContent(Settings.java:645)
at org.elasticsearch.common.settings.Settings.fromXContent(Settings.java:620)
at org.elasticsearch.common.settings.Settings.access$400(Settings.java:82)
at org.elasticsearch.common.settings.Settings$Builder.loadFromStream(Settings.java:1093)
... 8 more
Caused by: while scanning for the next token
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchMoreTokens(ScannerImpl.java:420)
at org.yaml.snakeyaml.scanner.ScannerImpl.checkToken(ScannerImpl.java:226)
at org.yaml.snakeyaml.parser.ParserImpl$ParseBlockMappingKey.produce(ParserImpl.java:557)
at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(ParserImpl.java:157)
at org.yaml.snakeyaml.parser.ParserImpl.getEvent(ParserImpl.java:167)
at com.fasterxml.jackson.dataformat.yaml.YAMLParser.nextToken(YAMLParser.java:340)
... 13 more```
Hi @nijanthan0,
it looks like you have TAB characters in your elasticsearch.yml file. Tab characters are forbidden in yaml files. You will need to remove any tab characters from the file.
