Problem in using native script
Hi.
I followed instructions on the page "git://gist.github.com/
1043766.git".
But I am getting following error.
ClassCastException[in.vedantu.search.scripts.UserRelativeScript cannot
be cast to org.elasticsearch.script.NativeScriptFactory
Does somebody know what the problem is?
Regards.
does UserRelativeScript extend/implement NativeScriptFactory?
On Thu, Jul 7, 2011 at 10:18 AM, nachiket bhagwat <nachiketbhagwat@gmail.com
wrote:
Hi.
1043766.git".
Regards.
Paul Loy
paul@keteracel.com
http://uk.linkedin.com/in/paulloy
Yes.
But I am not sure if my perception of binding classes into jar was
correct.
All I did was I took Script and ScriptFactory classes and put them in
a new folder and ran following command.
jar -cvf myjar.jar classfolder.
Is this the correct way?
On Thu, Jul 7, 2011 at 10:18 AM, nachiket bhagwat <nachiketbhag...@gmail.com
wrote:
Hi.
1043766.git".
Regards.
Paul Loy
p...@keteracel.comhttp://uk.linkedin.com/in/paulloy
what was the output when you ran the jar command?
On Fri, Jul 8, 2011 at 4:40 AM, nachiket bhagwat
nachiketbhagwat@gmail.comwrote:
Yes.
correct.
wrote:
Hi.
1043766.git".
Regards.
Paul Loy
Paul Loy
paul@keteracel.com
adding: in/(in = 0) (out= 0)(stored 0%)
adding: in/vedantu/(in = 0) (out= 0)(stored 0%)
adding: in/vedantu/search/(in = 0) (out= 0)(stored 0%)
adding: in/vedantu/search/scripts/(in = 0) (out= 0)(stored 0%)
adding: in/vedantu/search/scripts/UserRelativeScript.class(in = 680)
(out= 402)(deflated 40%)
adding: in/vedantu/search/scripts/UserRelativeScriptFactory.class(in =
943) (out= 455)(deflated 51%)
nachiketbhag...@gmail.comwrote:
Yes.
correct.
wrote:
Hi.
1043766.git".
Regards.
Paul Loy
Paul Loy
Hmm, that looks OK to me. Can you gist more of the logs around the exception
please?
On Fri, Jul 8, 2011 at 11:30 AM, nachiket bhagwat <nachiketbhagwat@gmail.com
Yes.
correct.
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
paul@keteracel.com
Thanks paul.
Logs are at git://gist.github.com/1071587.git.
please?
On Fri, Jul 8, 2011 at 11:30 AM, nachiket bhagwat <nachiketbhag...@gmail.com
Yes.
correct.
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
hmm, and what is your config?
On Fri, Jul 8, 2011 at 11:57 AM, nachiket bhagwat <nachiketbhagwat@gmail.com
wrote:
Thanks paul.
exception
please?
Yes.
correct.
in
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
paul@keteracel.com
Caused by: java.lang.ClassCastException:
in.vedantu.search.scripts.UserRelativeScript cannot be cast to
Is this because you need to be specifying the Factory not the Script in your
conf?
nachiketbhagwat@gmail.com> wrote:
Thanks paul.
exception
please?
Yes.
correct.
in
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
paul@keteracel.com
Paul Loy - Amihan Entertainment | LinkedIn
Paul Loy
paul@keteracel.com
Yes.
I guess that was the problem.
Now the script is working fine.
Thanks Paul.
conf?
nachiketbhag...@gmail.com> wrote:
Thanks paul.
exception
please?
Yes.
correct.
in
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
p...@keteracel.com
Paul Loy
Hi. There is another problem. Though it has nothing to do with above
one.
I want to add parameters to my script.
I referenced this document
Passing parameters to native script : 'http://groups.google.com/a/
elasticsearch.com/group/users/browse_thread/thread/59b85fab8e35f1e3'
Now my ScriptFactory class became a factory that simply creates an
AbstractFloatScript:
The file is at git://gist.github.com/1073346.git.
Now I am getting following error.
git://gist.github.com/1073348.git
Isn't this the right way to pass parameters?
Regards.
On Jul 9, 8:13 am, nachiket bhagwat nachiketbhag...@gmail.com wrote:
Yes.
Thanks Paul.
conf?
On Fri, Jul 8, 2011 at 11:57 AM,nachiketbhagwat <
Thanks paul.
exception
please?
On Fri, Jul 8, 2011 at 11:30 AM,nachiketbhagwat <
On Fri, Jul 8, 2011 at 4:40 AM,nachiketbhagwat
Yes.
correct.
in
On Thu, Jul 7, 2011 at 10:18 AM,nachiketbhagwat <
wrote:
Hi.
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
p...@keteracel.com
Paul Loy
Well it looks like it can't find the nested ($1) class. Did you remake your
jar correctly?
On Sat, Jul 9, 2011 at 6:19 AM, nachiket bhagwat
one.
Regards.
Yes.
Thanks Paul.
your
conf?
Thanks paul.
exception
please?
adding:
Yes.
jar was
correct.
put them
in
wrote:
Hi.
gist.github.com/
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
p...@keteracel.com
Paul Loy
Paul Loy
paul@keteracel.com
Yes. In the same way.
I just wrote the factory class and did NOT write the script class.
Instead I wrote my runAsFloat function in factory class itself.
public ExecutableScript newScript(final Map<String, Object> params) {
return new AbstractFloatSearchScript() {
        @Override
        public float runAsFloat() {
           ///My function
The problem is still persisting. The same problem as I mentioned
above.
git://gist.github.com/1073348.git.
My jar file is constructed correctly. I am sure about that. Can there
be any other reason for this?
Regards.
jar correctly?
one.
Regards.
Yes.
Thanks Paul.
your
conf?
Thanks paul.
exception
please?
adding:
Yes.
jar was
correct.
put them
in
wrote:
Hi.
gist.github.com/
1043766.git".
cannot
Regards.
Paul Loy
Paul Loy
Paul Loy
Paul Loy
p...@keteracel.com
Paul Loy
Paul Loy
