I've seen similar topics here, but couldnt dig an answer that solved my problem. So again, when installing kibana 5.0.0-rc1 I am getting the following error when opening the timelion view (everything else seems to work in kibana):
Error: in cell #1: [reduce_search_phase_exception] [reduce]
at throwWithCell (/opt/kibana/src/core_plugins/timelion/server/handlers/chain_runner.js:30:11)
at /opt/kibana/src/core_plugins/timelion/server/handlers/chain_runner.js:156:13
at arrayEach (/opt/kibana/node_modules/lodash/index.js:1289:13)
at Function.<anonymous> (/opt/kibana/node_modules/lodash/index.js:3345:13)
at /opt/kibana/src/core_plugins/timelion/server/handlers/chain_runner.js:148:9
at tryCatcher (/opt/kibana/node_modules/bluebird/js/main/util.js:26:23)
at Promise._settlePromiseFromHandler (/opt/kibana/node_modules/bluebird/js/main/promise.js:503:31)
at Promise._settlePromiseAt (/opt/kibana/node_modules/bluebird/js/main/promise.js:577:18)
at Promise._settlePromises (/opt/kibana/node_modules/bluebird/js/main/promise.js:693:14)
at Async._drainQueue (/opt/kibana/node_modules/bluebird/js/main/async.js:123:16)
at Async._drainQueues (/opt/kibana/node_modules/bluebird/js/main/async.js:133:10)
at Immediate.Async.drainQueues (/opt/kibana/node_modules/bluebird/js/main/async.js:15:14)
at runCallback (timers.js:574:20)
at tryOnImmediate (timers.js:554:5)
at processImmediate [as _immediateCallback] (timers.js:533:5)
Strange thing, this only happens on my server, local installation is working fine. What am I missing on the server, any dependency, port to be opened, whatever?
[2016-10-24T09:39:56,023][DEBUG][o.e.a.s.TransportSearchAction] [enter.your.host.here] failed to reduce search
org.elasticsearch.action.search.ReduceSearchPhaseException: [reduce]
at org.elasticsearch.action.search.SearchQueryThenFetchAsyncAction$2.onFailure(SearchQueryThenFetchAsyncAction.java:143) [elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.onFailure(ThreadContext.java:490) [elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:39) [elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_111]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_111]
Caused by: java.lang.IllegalStateException: scripts of type [inline], operation [aggs] and lang [expression] are disabled
at org.elasticsearch.script.ScriptService.compile(ScriptService.java:223) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.pipeline.bucketscript.BucketScriptPipelineAggregator.reduce(BucketScriptPipelineAggregator.java:95) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.InternalAggregation.reduce(InternalAggregation.java:144) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.InternalAggregations.reduce(InternalAggregations.java:158) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.bucket.filters.InternalFilters$InternalBucket.reduce(InternalFilters.java:100) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.bucket.filters.InternalFilters.doReduce(InternalFilters.java:205) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.search.aggregations.InternalAggregation.reduce(InternalAggregation.java:142) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.action.search.SearchPhaseController.merge(SearchPhaseController.java:493) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.action.search.SearchQueryThenFetchAsyncAction$2.doRun(SearchQueryThenFetchAsyncAction.java:132) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:504) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:37) ~[elasticsearch-5.0.0-rc1.jar:5.0.0-rc1]
... 3 more
[2016-10-24T09:39:56,028][WARN ][r.suppressed ] path: /metric*/_search, params: {index=metric*}
(reduced bc body limit)
Actually the problem is that I am using AWS Elasticsearch where AWS don't allow to make any changes in the settings. Is there any way to do it their or am I missing something?
