Problem with elasticsearch 8 and php application while using docker
Hi, everybody.
I have a problem with elasticsearch 8 and docker, which I am sitting on last 3-4 hours.
I have next docker compose configuration which consist of php symfony application and elasticsearch single node with security enabled options.
version: '2.2'
services:
  php_symfony_application:
    build: ./ci/php
    container_name: "php_symfony_application"
    volumes:
      - .:/var/www/php_symfony_application
  setup:
    image: docker.elastic.co/elasticsearch/elasticsearch:${STACK_VERSION}
    container_name: "udemy_phpes_setup"
    volumes:
      - certs:/usr/share/elasticsearch/config/certs
    user: "0"
    command: >
      bash -c '
        if [ x${ELASTIC_PASSWORD} == x ]; then
          echo "Set the ELASTIC_PASSWORD environment variable in the .env file";
          exit 1;
        fi;
        if [ ! -f certs/ca.zip ]; then
          echo "Creating CA";
          bin/elasticsearch-certutil ca --silent --pem -out config/certs/ca.zip;
          unzip config/certs/ca.zip -d config/certs;
        fi;
        if [ ! -f certs/certs.zip ]; then
          echo "Creating certs";
          echo -ne \
          "instances:\n"\
          "  - name: elasticsearch8\n"\
          "    dns:\n"\
          "      - elasticsearch8\n"\
          "      - localhost\n"\
          "    ip:\n"\
          "      - 127.0.0.1\n"\
          > config/certs/instances.yml;
          bin/elasticsearch-certutil cert --silent --pem -out config/certs/certs.zip --in config/certs/instances.yml --ca-cert config/certs/ca/ca.crt --ca-key config/certs/ca/ca.key;
          unzip config/certs/certs.zip -d config/certs;
        fi;
        echo "Setting file permissions"
        chown -R root:root config/certs;
        find . -type d -exec chmod 750 \{\} \;;
        find . -type f -exec chmod 640 \{\} \;;
        echo "Waiting for Elasticsearch availability";
        until curl -s --cacert config/certs/ca/ca.crt https://elasticsearch8:9200 | grep -q "missing authentication credentials"; do sleep 30; done;
        echo "All done!";
    healthcheck:
      test: [ "CMD-SHELL", "[ -f config/certs/elasticsearch8/elasticsearch8.crt ]" ]
      interval: 1s
      timeout: 5s
      retries: 120
  elasticsearch8:
    depends_on:
      setup:
        condition: service_healthy
    container_name: "elasticsearch8"
    volumes:
      - ./ci/data/es/db:/usr/share/elasticsearch/data
    ports:
      - ${ES_PORT}:9200
    expose:
      - ${ES_PORT}
    environment:
      - node.name=elasticsearch8
      - cluster.name=${CLUSTER_NAME}
      - cluster.initial_master_nodes=elasticsearch8
      - ELASTIC_PASSWORD=${ELASTIC_PASSWORD}
      - bootstrap.memory_lock=true
      - xpack.security.enabled=true
      - xpack.security.http.ssl.enabled=true
      - xpack.security.http.ssl.key=certs/elasticsearch8/elasticsearch8.key
      - xpack.security.http.ssl.certificate=certs/elasticsearch8/elasticsearch8.crt
      - xpack.security.http.ssl.certificate_authorities=certs/ca/ca.crt
      - xpack.security.http.ssl.verification_mode=certificate
      - xpack.security.transport.ssl.enabled=true
      - xpack.security.transport.ssl.key=certs/elasticsearch8/elasticsearch8.key
      - xpack.security.transport.ssl.certificate=certs/elasticsearch8/elasticsearch8.crt
      - xpack.security.transport.ssl.certificate_authorities=certs/ca/ca.crt
      - xpack.security.transport.ssl.verification_mode=certificate
      - xpack.license.self_generated.type=${LICENSE}
    ulimits:
      memlock:
        soft: -1
        hard: -1
    healthcheck:
      test:
            "CMD-SHELL",
            "curl -s --cacert config/certs/ca/ca.crt https://localhost:9200 | grep -q 'missing authentication credentials'",
      interval: 10s
      timeout: 10s
      retries: 120
volumes:
  certs:
    driver: local
I can connect from local machine with curl using certificate:
 curl --cacert path/to/ca.crt -u elastic:test1234 https://localhost:9202/_cluster/health?prett
All works in that case as it should be.
But while being inside php application container and running the curl with certificate:
curl --cacert path/to/ca.crt -u elastic:test1234 https://elasticsearch8:9200/_cluster/health?pretty
I am getting the error:
curl: (35) error:14094417:SSL routines:ssl3_read_bytes:sslv3 alert illegal parameter
As result (at least I suppose it is the reason) while trying to connect to the cluster via elasticsearch-php client with next code:
$client = ClientBuilder::create()
    ->setHosts(['https://elasticsearch8:9200'])
    ->setBasicAuthentication('elastic', 'test1234')
    ->setCABundle('path/to/http_ca.crt')
    ->build();
I am getting the error: "No alive nodes. All the 1 nodes seem to be down."
Seems it is some issue related to the docker,dns and certificates altogether. I completely stuck with that and have no more ideas how to resolve the problem.
Can anybody save my day? I would be very grateful for any ideas.
