Problem with geoip.location field conflict
hello,
I am facing an issue with the geoip.location.
This is the error screen shot
The filebeat indexed template is
  "mappings": {
    "_default_": {
      "_all": {
        "enabled": true,
        "norms": {
          "enabled": false
      "dynamic_templates": [
          "template1": {
            "mapping": {
              "doc_values": true,
              "ignore_above": 1024,
              "index": "not_analyzed",
              "type": "{dynamic_type}"
            "match": "*"
      "properties": {
        "@timestamp": {
          "type": "date"
        "message": {
          "type": "string",
          "index": "analyzed"
        "offset": {
          "type": "long",
          "doc_values": "true"
        "geoip"  : {
          "dynamic": true,
          "properties" : {
            "location" : { "type" : "geo_point" }
  "settings": {
    "index.refresh_interval": "5s"
  "template": "filebeat-*"
Hi there,
I think you have a mapping conflict. Can you click the "Edit" icon for the field to see the types it's being mapped to for each index? To solve this problem, you'll have to re-index the data that's not actually a geo_point type.
Does this help? Also, you might try cross-posting in the Beats forum if you have further Beats-related questions.
Thanks,
CJ
In addition you might want to consider using the standard template that is provided by Filebeat and then "layer" on an additional template for the geoip field like:
PUT _template/filebeat-1
  "order": 1,
  "template": "filebeat-*",
  "mappings": {
    "_default_": {
      "properties": {
        "geoip"  : {
          "properties" : {
Re-indexing is covered here. Basically you find the indices that aren't using the geo_point type and reindex them, then delete the old index. Like
POST _reindex
  "source": {
    "index": "filebeat-2017.01.12"
  "dest": {
    "index": "filebeat-2017.01.12a"
Then once the operation is successful you can delete the old index. Then refresh the kibana mapping and the conflicts should be resolved.
