Hey, folks! How are you?
I'm having some troubles with, I believe, mapping. I have a JsonElement field type that is not being saved in my elastic. I'm using C#, working with NEST client.
Invalid NEST response built from a successful (200) low level call on POST: /transactions/_bulk?pretty=true&error_trace=true
# Invalid Bulk items:
operation[0]: index returned 201 _index: transactions _type: _id: b260dfdb-6610-4b43-a401-406d3cdc4b55 _version: 1 error:
# Audit trail of this API call:
- [1] HealthyResponse: Node: http://localhost:9200/ Took: 00:00:02.6124975
# Request:
{"index":{"_id":"b260dfdb-6610-4b43-a401-406d3cdc4b55"}}
{"chargeId":"3c8fe6ed-fab5-445a-8b85-61bad3b88efb","status":"Rejected","updatedAt":"0001-01-01T00:00:00","externalPart":{"name":"Valentina","document":"673.596.828-00"},"value":{"original":"720.32","updated":"720.32"},"events":[{"transactionId":"b260dfdb-6610-4b43-a401-406d3cdc4b55","internalTransactionId":"2eb56d3c-a7a0-413e-8b63-3473e1f2350e","externalId":"3c8fe6ed-fab5-445a-8b85-61bad3b88efb","status":"Rejected","type":"TransactionCreated","metadata":{"valueKind":3},"processedAt":"2023-04-03T14:46:28.8144858-03:00"}],"account":{"id":"00000000-0000-0000-0000-000000000000"},"expose":false,"id":"b260dfdb-6610-4b43-a401-406d3cdc4b55"}
# Response:
"took" : 19,
"errors" : false,
"items" : [
"index" : {
"_index" : "transactions",
"_id" : "b260dfdb-6610-4b43-a401-406d3cdc4b55",
"_version" : 1,
"result" : "created",
"_shards" : {
"total" : 2,
"successful" : 1,
"failed" : 0
"_seq_no" : 7,
"_primary_term" : 2,
"status" : 201
# TCP states:
Established: 38
TimeWait: 52
# ThreadPool statistics:
Worker:
Busy: 1
Free: 32766
Min: 8
Max: 32767
IOCP:
Busy: 1
Free: 999
Min: 8
Max: 1000
When I insert the same metadata field through console, the transaction works, but when I do via code, works partially. When I verify the result through the console, I got this:
"metadata" : {"valueKind" : 3},
I verified that the field "metadata" is mapped as "flattened".
