Hey Guys,
today we encoutered a problem while requesting some data from our ES db
from an other server in our network.
All that the other server does is executing the following request:
curl -XGET 'https://elasticsearch-server:443/logstash-2014.09.10,logstash-2014.09.09/_search?pretty' -d '{
"filtered": {
"bool": {
"should": [
"query_string": {
"query": "field:*"
"filter": {
"bool": {
"must": [
"range": {
"@timestamp": {
"from": 1410261816133,
"to": 1410348216133
"fquery": {
"query_string": {
"query": "logsource:("servername")"
"_cache": true
"highlight": {
"fields": {},
"fragment_size": 2147483647,
"pre_tags": [
"@start-highlight@"
"post_tags": [
"@end-highlight@"
"size": 100,
"sort": [
"@timestamp": {
"order": "desc",
"ignore_unmapped": true
"@timestamp": {
"order": "desc",
which simply count how much events 1 server over 24 hours got.
But if this request lead to some abnormal behavior of elasticsearch, we much of the following error messages in our es-log:
[2014-09-10 13:12:32,938][DEBUG][http.netty               ] [NodeName] Caught exception while handling client http traffic, closing connection [id: 0x5fd6fd9f, /:40784 :> /<IP of the ES server:9200]
java.nio.channels.ClosedChannelException
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.cleanUpWriteBuffer(AbstractNioWorker.java:433)
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.writeFromUserCode(AbstractNioWorker.java:128)
at org.elasticsearch.common.netty.channel.socket.nio.NioServerSocketPipelineSink.handleAcceptedSocket(NioServerSocketPipelineSink.java:99)
at org.elasticsearch.common.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:36)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779)
at org.elasticsearch.common.netty.channel.Channels.write(Channels.java:725)
at org.elasticsearch.common.netty.handler.codec.oneone.OneToOneEncoder.doEncode(OneToOneEncoder.java:71)
at org.elasticsearch.common.netty.handler.codec.oneone.OneToOneEncoder.handleDownstream(OneToOneEncoder.java:59)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591)
at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582)
at org.elasticsearch.common.netty.channel.Channels.write(Channels.java:704)
at org.elasticsearch.common.netty.channel.Channels.write(Channels.java:671)
at org.elasticsearch.common.netty.channel.AbstractChannel.write(AbstractChannel.java:248)
at org.elasticsearch.http.netty.NettyHttpChannel.sendResponse(NettyHttpChannel.java:173)
at org.elasticsearch.rest.action.support.RestResponseListener.processResponse(RestResponseListener.java:43)
at org.elasticsearch.rest.action.support.RestActionListener.onResponse(RestActionListener.java:49)
at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction$AsyncAction.innerFinishHim(TransportSearchQueryThenFetchAction.java:157)
at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction$AsyncAction.finishHim(TransportSearchQueryThenFetchAction.java:139)
at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction$AsyncAction.moveToSecondPhase(TransportSearchQueryThenFetchAction.java:90)
at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction.innerMoveToSecondPhase(TransportSearchTypeAction.java:404)
at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction.onFirstPhaseResult(TransportSearchTypeAction.java:198)
at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction$1.onResult(TransportSearchTypeAction.java:174)
at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction$1.onResult(TransportSearchTypeAction.java:171)
at org.elasticsearch.search.action.SearchServiceTransportAction$23.run(SearchServiceTransportAction.java:526)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745
As soon as we active this request from the remote server we get a whole lot of this error messages and everything in elasticsearch slows down pretty hard (Even Kibana request get stuck in the queue).
Anybody got an idea why this is happening?
Any feedback is appreciated.
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/85627251-b4be-4031-870a-2bd621d0973c%40googlegroups.com.
