Problems setting up documents using geo_point
I am using C# Nest version 8, and have an Index of hotels with GeoLocation.
My document have the following property:
public GeoCoordinate geoCoordinate { get; set; }
When I try to do a geo search I end up with an empty array:
var result = await _client.SearchAsync<EHotel>(s => s
    .Index(HotelIndex)
    .Size(5000)
    .Query(q => q
        .GeoDistance(gd => gd
            .Field(f => f.geoCoordinate)
            .DistanceType(GeoDistanceType.Arc)
            .Location(coordinate)
            .Distance(distance, DistanceUnit.Kilometers)
    .Explain()
I've been searching a lot on the topic but seems I'm not able to find the a solution.
When I go to Kibana, the geoCoordinate property is a number and not a geo_point.
Can someone help me how to solve this with nest?
Have you created the mapping for your field before indexing any data?
Can you share your mappings? A geo_point field needs to be mapped before indexing any data on it.
I could indeed be the case.
I'm not sure how to see the mappings in Nest 8.
I'm not sure how you would do it as well as I do not use it and I always set the mapping using templates, never directly on code.
But if you didn't created the mapping for the geo_point then it will not work as a geo_point, the mapping needs to be created before indexing the data.
You can read more about it here.
I found a way to get the mapping, and you're right the mappings are wrong.
var response = _client.Indices.GetMapping<StringResponse>(m => m.Index(HotelIndex));
var index = response.Indices.FirstOrDefault();
var mapproperties = index.Value.Mappings.Properties;
I look into a way to create the index, and see if automap solves the issues.
Thanks for reaching out :slight_smile:
