Problems with geo_point
Hello all,
I'm very new to elastic, so please bear with me. I'm trying to get a data type 'geo_point' in ES 6.3 via a template referenced in my logstash pipeline. I'm getting geo data populating in elasticsearch, just not a geo_point data type that's usable with the coordinate map. Here's my ES template:
"template" : "paloalto-",
"version" : 60001,
"settings" : {
"index.refresh_interval" : "5s"
"mappings" : {
"default" : {
"dynamic_templates" : [ {
"message_field" : {
"path_match" : "message",
"match_mapping_type" : "string",
"mapping" : {
"type" : "text",
"norms" : false
"string_fields" : {
"match" : "
"mapping" : {
"type" : "text", "norms" : false,
"fields" : {
"keyword" : { "type": "keyword", "ignore_above": 256 }
"properties" : {
"@timestamp": { "type": "date"},
"@version": { "type": "keyword"},
"DestinationGeo" : {
"dynamic": true,
"properties" : {
"ip": { "type": "ip" },
"location" : { "type" : "geo_point" },
"latitude" : { "type" : "half_float" },
"longitude" : { "type" : "half_float" }
And here's the relevant section from my pipeline:
if [DestinationAddress] and [DestinationAddress] !~ "(^127.0.0.1)|(^10.)|(^172.1[6-9].)|(^172.2[0-9].)|(^172.3[0-1].)|(^192.168.)|(^169.254.)" {
geoip {
database => "/opt/logstash/GeoLite2-City.mmdb"
source => "DestinationAddress"
target => "DestinationGeo"
#Delete 0,0 in DestinationGeo.location if equal to 0,0
if ([DestinationGeo.location] and [DestinationGeo.location] =~ "0,0") {
mutate {
replace => [ "DestinationAddress.location", "" ]
if [Type] == "TRAFFIC" {
index => "paloalto-traffic-%{DeviceName}-%{+YYYY.MM.dd}"
template => "/opt/logstash/elasticsearch-template.json"
template_overwrite => true
I'm not seeing any errors, so I assume I've misunderstood a piece of this. Can anyone see anything obvious missing from this configuration that would prevent the geo_point data field from populating? Do I need to install the geoip plugin on all nodes before this field will show up?
there are a couple of "gotcha"s here.
  • The template is just a template, used by Elasticsearch when creating new indices. Updating it does not update indices that already exist.
  • Due to the way Elasticsearch uses Lucene under the hood, it is not possible to change the type of a field in an index so you may have to delete the index and start over (or index to a new field with a new name and use it instead)
Hi yaauie, thanks for the reply. I've deleted the index after any changes to the template and let the index recreate applying the new template. I'm still not getting any geo_point data types in my datasets within ES. I feel like I've got something mapped wrong, but my understanding of templates is pretty limited at the moment.
Nothing specific is standing out to me about your template.
What is the current index mapping? The Get Mapping API is useful here.
It's a lot of data, too much to post. It looks like there are two fields for "DestinationGeo". I'm guessing that is my issue?
        "dynamic" : "true",
        "properties" : {
          "ip" : {
            "type" : "ip"
          "latitude" : {
          "location" : {
          "longitude" : {
        "dynamic" : "true",
        "properties" : {
          "city_name" : {
            "type" : "text",
            "norms" : false,
            "fields" : {
              "keyword" : {
                "type" : "keyword",
                "ignore_above" : 256
          "continent_code" : {
            "type" : "text",
            "norms" : false,
            "fields" : {
              "keyword" : {
                "type" : "keyword",
          "country_code2" : {
            "type" : "text",
            "norms" : false,
            "fields" : {
              "keyword" : {
                "type" : "keyword",
          "country_code3" : {
            "type" : "text",
            "norms" : false,
            "fields" : {
              "keyword" : {
                "type" : "keyword",
          "country_name" : {
            "type" : "text",
            "norms" : false,
            "fields" : {
              "keyword" : {
                "type" : "keyword",
Also here's the JSON that's getting passed into ES:
"DestinationGeo": {
  "country_code2": "US",
  "region_code": "CA",
  "longitude": -122.0574,
  "latitude": 37.419200000000004,
  "city_name": "Mountain View",
  "region_name": "California",
  "country_code3": "US",
  "location": {
    "lon": -122.0574,
    "lat": 37.419200000000004
But the data type is '?' for almost all of my geo data where other data types are defined. So I guess I'm missing a definer somewhere for the datatype and ES is just making a best effort?
Elasticsearch can't have two fields with the same name in an index, so something's not quite right; can you paste the entire mapping in a gist and link to it?
Sure, Here's the link. Is it because I am using the same field name in the Template that I am using in the logstash pipeline? If so, should I just change the template field to another name? I thought the template was supposed to reference the field being processed.. am I completely wrong on that?
The top-level wildcards indicate to me that the doc you linked to was probably your templates. Can you get the effective mapping from the specific index?
curl -X GET "${hostname}:${port}/${index}/_mapping/_doc"
We're stretching pretty firmly into Elasticsearch territory, so it may be helpful to post your questions in the Elasticsearch forum.
