I want my search work like all the search terms searched with AND results first and then with OR results.
example,
Search term - borosil infrastructure
the result should come like -
borosil infrastructure ltd
private sector borosil infrastructure
borosil ltd
borosil carp
infrastructure ltd
infrastructure info
first i am giving preference to AND results then OR...
My query is
"from": 0,
"size": 100,
"function_score": {
"bool": {
"must": [
"multi_match": {
"query": "example",
"fields": [
"field1^6","field1._2gram","field1._index_prefix^12",
"field2^2","field2._2gram^4","field2._index_prefix"
"type": "bool_prefix"
"should": [
"multi_match": {
"query": "example",
"fields": [
"type": "bool_prefix",
"operator": "and",
"boost": 1000
"filter": {
"bool":{
"must":[
"term": {
"Field3": 0
"term": {
"Field4": 1
"functions": [
"filter": {
"match_all": {
"boost": 1
"script_score": {
"script": {
"source": "doc['P_score'].value != null && doc['P_score'].value !=0 ? (doc['P_score'].value * 100000) + (doc['W_score'].value * 100000) : (doc['W_score'].value * 100000)",
"lang": "painless"
"boost": 1,
"boost_mode": "avg",
"score_mode": "avg"
"sort": [
"_score": {
"order": "desc"
the results are coming as per desired in some cases but in some cases its not behaving as needed.
then I changed the query with AND in must and Or in should
"bool": {
"must": [
"multi_match": {
"query": "example",
"fields": [
"operator": "AND"
"should": [
"multi_match": {
"query": "example",
"fields": [
"operator": "OR"
but It end up in showing only AND results.. and no OR results are coming...
