I'm having some trouble with multi_field, perhaps some of you guys
could shed some light on what I'm doing wrong. After I inserted some
documents, I get 0 hits for any searches of the field name.untouched
or name.ngram. I am successful with the main field just searching on
name. For example, the following returns nothing even though i know
the term is there exactly:
Can you gist a sample with setting up the index, the mappings, indexing sample doc(s) and then showing the search request that do not work for you? It would help a lot. (see http://www.elasticsearch.org/help).
Here is the gist. Thanks very much for any help that can be
provided. I'm mostly interested in if I'm setting up the mapping
incorrectly, or using the multi_field or ngram types incorrectly.
Can you gist a sample with setting up the index, the mappings, indexing sample doc(s) and then showing the search request that do not work for you? It would help a lot. (seehttp://www.elasticsearch.org/help).
Thanks a lot for pointing this out. This was the problem.
I was wondering, is it possible to apply this mapping to all types
within an index? For example, if I wanted to set the mapping for the
"name" field for all types of the index "test", can I do that?
Bring back this old thread, but I have a followup question. Does edge
ngram filtered fields support prefix or phrase-prefix queries? My goal is
to prefer results which have the same word ordering as the query, ie if I
search "Jack John" prefer "Jack Johnson" over "John Jackson". Can this be
done via a query type/parameter, or custom scoring?
logo are trademarks of the
Apache Software Foundation
