Range Aggregation using difference between 2 fields
I want to create a visualization where buckets must be created with range or a value(0-5, 5-10, 10-15).
This value is not available in a field but should be derived from difference between 2 fields.
Hey @Karthik2411, you can use a Scripted Field to calculate the difference, and then use this in a range aggregation:
Thank you so much for the reply @Brandon_Kobel . That helped me.
