Script field work in Preview results but not work outside
I try create the topic field of my log message from matching string
This is my script, it work when i test it on preview.
But it error when I use it on visualize or discover
       if(doc['message.keyword'].size() !=0 ){
            if(/(unexpected)/.matcher(doc['message.keyword'].value).find()){
                return "Unexpected Error";
            else if(/(memory)/.matcher(doc['message.keyword'].value).find()){
                return "Memory Error";
            else if(/(memories)/.matcher(doc['message.keyword'].value).find()){
            else if(/(equipment)/.matcher(doc['message.keyword'].value).find()){
                return "Equipment Error";
            else if(/(equipments)/.matcher(doc['message.keyword'].value).find()){
            else if(/(parse default_repo)/.matcher(doc['message.keyword'].value).find()){
                return " Parse default_repo Failed";
            else if(/(agent failed)/.matcher(doc['message.keyword'].value).find()){
                return "Agent Failed";
            else if(/(process terminated)/.matcher(doc['message.keyword'].value).find()){
                return "Process Terminated with Error";
            else if(/(timeout while waiting for task)/.matcher(doc['message.keyword'].value).find()){
                return "Task Startup Timeout";
            else if(/(transition call error)/.matcher(doc['message.keyword'].value).find()){
                return "Transition Call Error";
            else if(/(attempted status update)/.matcher(doc['message.keyword'].value).find()){
                return "Status Update of Task not in Roster";
            else if(/(end task)/.matcher(doc['message.keyword'].value).find()){
                return "End Task Error";
            else if(/(environment)/.matcher(doc['message.keyword'].value).find()){
                return "Environment Error";
            else if(/(error receiving event)/.matcher(doc['message.keyword'].value).find()){
                return "Receiving Event Error ";
            else if(/(descriptor constraints)/.matcher(doc['message.keyword'].value).find()){
                return "Descriptor Constraints not Satisfied";
            else if(/(cannot parse template)/.matcher(doc['message.keyword'].value).find()){
                return "Can't Parse Template";
            else if(/(failed to capture)/.matcher(doc['message.keyword'].value).find()){
                return "Capture stdout/stderr Error";
            else {return "Not Defined";}
        else return "Missing"
Can someone tell me how to fix this? or just point what I missing.
Hi and welcome to our community!
Seems the error message provided by Kibana isn't very useful, could you take a look at a single failing request in the Browsers dev tools, maybe paste the the result of a failing request here, or a screenshot? there should be more info provided why this is failing.
Here's a example for debugging in chrome:
Thx & best,
Matthias
