I want to index 1 billion records. each record has 2 attributes (attribute1 and attribute2).
each record that has same value in attribute1 must be merge. for example, I have two record
attribute1 attribute2
1 4
1 6
my elastic document must be
“attribute1”: 1
“attribute2”: 4,6
due to huge amount of data, I must to read a bulk (about 1000 records) and merge them based on the above rule (in memory) and then search them in ElasticSearch and merge them with search result and then index/reindex them.
In summary I have to Search and Index per bulk respectively.
I implemented this rule but in some cases Elastic does not return all results and some documents have been indexed duplicately.
after each Index I Refresh ElasticSearch so that it be ready for next search. but in some case it doesn’t work.
my index setting is followed as:
"test_index": {
"settings": {
"index": {
"refresh_interval": "-1",
"translog": {
"flush_threshold_size": "1g"
"max_result_window": "1000000",
"creation_date": "1464577964635",
"store": {
"throttle": {
"type": "merge"
"number_of_replicas": "0",
"uuid": "TZOse2tLRqGk-vHRMGc2GQ",
"version": {
"created": "2030199"
"warmer": {
"enabled": "false"
"indices": {
"memory": {
"index_buffer_size": "40%"
"number_of_shards": "5",
"merge": {
"policy": {
"max_merge_size": "2g"
how can I resolve this problem?
Is there any other setting to handle this situation?
