Set "index.mapping.dimension_fields.limit" does not work
Hi everyone,
We would like to extend the number of dimension_fields of our TSDS by
POST _index_template/ds-micrometer-metrics-prod
  "index_patterns": [
    "micrometer"
  "data_stream": {},
  "template": {
    "settings": {
      "index.mode": "time_series",
      "index.mapping.dimension_fields.limit": 25,
      "index.routing_path": [
        "identifier"
  "composed_of": [
    "metrics-timeseries-datastream-mappings",
    "metrics-timeseries-datastream-prod-settings"
  "priority": 500
And we can get the template by
GET _index_template/ds-micrometer-metrics-prod
And result
  "index_templates": [
      "name": "ds-micrometer-metrics-prod",
        "template": {
          "settings": {
            "index": {
              "mapping": {
                "dimension_fields": {
                  "limit": "25"
However, when we tried to apply new mappings which has 23 dimension fields, we got error:
  "error": {
    "root_cause": [
        "reason": "Limit of total dimension fields [21] has been exceeded"
  "status": 400
Do you know why and how to fix this issue?
Elasticsearch: 8.8.1
Best regards,
For anyone has same issue.
You have to set the limit at the mapping not at the _index_template
POST _component_template/metrics-timeseries-datastream-mappings
    "template":
        "settings":
            "index":
                "mode": "time_series",
                "routing_path":
                "mapping":
                    "dimension_fields":
                        "limit": "25"
