I'm trying to setup an ILM policy that deletes my index every 3 days, and creates a new one. Here's my attempt for achieving that:
const policyName = "hot_delete_twitter_stream_indexing_policy"
await ESClient.ilm.putLifecycle({
policy: policyName,
body: {
policy: {
phases: {
hot: {
actions: {
rollover: {
max_age: "30s",
delete: {
actions: {
delete: {},
const rolloverIndexAliasName = `${process.env.ES_INDEX}_rollover_index`
await ESClient.indices.create({
index: process.env.ES_INDEX,
body: {
settings: {
"index.lifecycle.name": policyName,
"index.lifecycle.rollover_alias": rolloverIndexAliasName,
mappings: {
properties: {
author_username: { type: "keyword" },
id: { type: "keyword" },
timestamp: { type: "keyword" },
text: { type: "text" },
bounding_box: { type: "geo_shape" },
await ESClient.indices.putAlias({
Executing this code, when I add records to my index, and check the ILM explain endpoint after 30 seconds to check if my index is deleted, the index is still there, and I still can add records to it.
Here's the output of the ILM explain endpoint:
"indices": {
"expotwitt_tweets": {
"index": "expotwitt_tweets",
"managed": true,
"policy": "hot_delete_twitter_stream_indexing_policy",
"lifecycle_date_millis": 1638980335786,
"age": "20.71s",
"phase": "hot",
"phase_time_millis": 1638980335933,
"action": "rollover",
"action_time_millis": 1638980335933,
"step": "check-rollover-ready",
"step_time_millis": 1638980335933,
"phase_execution": {
"phase_definition": {
"min_age": "0ms",
"actions": {
"rollover": {
"max_age": "30s"
"version": 2,
"modified_date_in_millis": 1638980335739
And it remains the same after 30 seconds has passed.
Can you spot what am I doing wrong, or if there is an entirely different but better approach to achieve my goal described above? Thank you.
