I am started using elastic search server for my application when i am trying to install the shield & license plugins in Solaris OS by using putty,
Installation command:- 1. bin/plugin -i elasticsearch/license/latest Error:- bin/plugin:: No such file or directory
I mentioned my elastic search home directory as ES_HOME=/ElasticSearch/QA/node1 when i try to execute the above command in putty i am getting the error.
Note:- Please let me know if i done any wrong in setting ES_HOME Directory and as well as any other configuration details.
Please guide me some detailed explanation to install shield in ES..
I just manually downloaded the elasticsearch server from the below link
TAR https://download.elastic.co/elasticsearch/elasticsearch/elasticsearch-1.7.2.tar.gz
1. I used the command tar -zxvf elasticsearch-1.7.2.tar.gz to unzip the file.
2. I did some changes in elasticsearch.yml file for some performance tuning purpose.
3. File listing of bin directory in ES_HOME
4. I used CURL commands in putty for monitoring cluster health & state.
Note:- Please guide me to install the shield configuration
I think the first step is to figure out why bin/plugin fails to execute/be found for you. I see that the output you listed is for /Elasticsearch/QA/node2/bin instead of node1, but I doubt that is the problem.
Need to figure out the solution when executing the bin/plugin. The file listing in both node1 & node2 are same inside the bin folder. I took the sample screenshot from my system.
I tried the below command to install license plugin
logo are trademarks of the
Apache Software Foundation
