Snapshot Restore to 9.0.1 Fails Despite Setting `index.blocks.write=true` on Source Index in 8.7.1
Hi all,
I'm attempting to restore a snapshot from an Elasticsearch 8.7.1 cluster into a 9.0.1 cluster running via ECK on AWS EKS. I have full access to both clusters.
The snapshot was taken in 8.7.1 and includes some older indices originally created in version 7.4.2 ("index.version.created": 7040299). The restore fails on those indices with the following error:
"[my-snapshot-repository:daily-snap-...] cannot restore index [[my_index/...]] because it cannot be upgraded"
The index [my_index/...] created in version [7.4.2] with current compatibility version [7.4.2] must be marked as read-only using the setting [index.blocks.write] set to [true] before upgrading to 9.0.1.
Here’s what I’ve tried:
  1. On the 8.7.1 cluster, I set index.blocks.write=true for the affected index and took a new snapshot.
  2. Restore to 9.0.1 still failed with the same error.
  3. I then also set index.blocks.read_only=true, re-snapshotted, and tried again — still the same failure.
  4. To close the index and ensure it was in a clean state, I reverted index.blocks.read_only=false, closed the index, and took yet another snapshot — still no change in the error.
I’m explicitly not restoring global state or system indices, only the user index.
My Questions:
  1. Am I missing something about how index.blocks.write=true needs to be set for the upgrade path to work?
  2. Is there a reliable way to confirm that index.blocks.write=true is truly persisted in the snapshot?
  3. Is there any way to inspect index metadata or settings (e.g., index.blocks.*) in the snapshot, without restoring it?
  4. Is the only remaining option to reindex these indices into v8.7.1 — or is there a better workaround to avoid that (some of them are quite large)?
Any help or insights would be much appreciated — I’ve reviewed the docs and forums but can’t find a definitive answer on why the setting isn’t being respected during the restore.
Thanks in advance!
Looking at the code, I believe that today you need to use the put index block API in at least 8.18.0 before taking the snapshot.
At the very least this should be mentioned in the docs, but I can't immediately see a reason why Elasticsearch can't apply the appropriate blocks during the snapshot restore. Would you open a bug report at https://github.com/elastic/elasticsearch/issues?
Many thanks for your reply, @DavidTurner !
Does this mean we need to upgrade the cluster from v8.7.1 to v8.18.x (v8.18.2) before trying to set that index to read-only?
Does only Elasticsearch need to be upgraded or Kibana as well?
Finally, would steps above be enough or reindexing that index to v8 will still be required?
I'm asking as some of the answers on this forum suggest that restoring indices older than one major version require reindexing to the previous major version first.
For example: Problem with restoring old (6.8) indices on ES 8.6.1
Elasticsearch can only read indices one major version back. Elasticsearch 8.x can therefore only read indices created in Elasticsearch 7.0 or newer. You will need to restore your 6.x indices into a 7.x cluster and reindex before the new indices can be snapshotted and restored into Elasticsearch 8.x.
Also, the answer in Snapshot index compatibility suggests that simply restoring the old index into previous major version Elastic is not enough to enable restoring it to the Elastic with the latest major version.
Yes. Today at least, but this seems like a straight usability bug to me, we should be able to avoid this step and restore directly from the 8.7.x snapshot in some future 9.x version (if you report the bug).
I expect Kibana 8.7 will work with Elasticsearch 8.18 although you're expected to upgrade Kibana too. See e.g. these docs:
Running a minor version of Elasticsearch that is higher than Kibana will generally work in order to facilitate an upgrade process where Elasticsearch is upgraded first (e.g. Kibana 8.14 and Elasticsearch 8.15). In this configuration, a warning will be logged on Kibana server startup, so it’s only meant to be temporary until Kibana is upgraded to the same version as Elasticsearch.
No need to reindex.
That's how it was in 8.x and earlier versions, but 9.x versions can read indices that were created in 7.x.
For the avoidance of doubt, reindexing into an 8.x index will also work, you just don't have to do both. If you would rather not upgrade to ≥8.18.0 first then you can use reindex to achieve the same goal.
Thanks @DavidTurner again!
We have few quite large indices (and limited time for migration) so we're trying to avoid reindexing. That's why we followed the instructions around upgrading Elastic you suggested but restore failed again, with the same error.
These are the steps we took:
  1. Upgraded both Elastic and Kibana (in that order) to v8.18.2. GET / returns:
  "name": "*****",
  "cluster_name": "*****",
  "cluster_uuid": "****",
  "version": {
    "number": "8.18.2",
    "build_flavor": "default",
    "build_type": "docker",
    "build_hash": "c6b8d8d951c631db715485edc1a74190cdce4189",
    "build_date": "2025-05-23T10:07:06.210694702Z",
    "build_snapshot": false,
    "lucene_version": "9.12.1",
    "minimum_wire_compatibility_version": "7.17.0",
    "minimum_index_compatibility_version": "7.0.0"
  "tagline": "You Know, for Search"
At the same time, in our v9.0.1 instance, Kibana returns:
  "name": "*****",
  "cluster_uuid": "*****",
  "version": {
    "number": "9.0.1",
    "build_hash": "73f7594ea00db50aa7e941e151a5b3985f01e364",
    "build_date": "2025-04-30T10:07:41.393025990Z",
    "lucene_version": "10.1.0",
    "minimum_wire_compatibility_version": "8.18.0",
    "minimum_index_compatibility_version": "8.0.0"
  1. Re-applied setting index.blocks.write=true (after having it first set to false)
  2. Created a new snapshot and verified that it's version changed. It is now: "version": "8.18.0"
  3. Attempted to restore it into a v9.0.1 cluster. Restore failed again with the same error:
  "error" : {
    "root_cause" : [
        "type" : "snapshot_restore_exception",
        "reason" : "[my-snapshot-repository:daily-snap-...-0_N5-aq...] cannot restore index [[my_index/f1dN...]] because it cannot be upgraded"
    "reason" : "[my-snapshot-repository:daily-snap-...-0_N5-aq...] cannot restore index [[my_index/f1dN...]] because it cannot be upgraded",
    "caused_by" : {
      "type" : "illegal_state_exception",
      "reason" : "The index [my_index/YbjR...] created in version [7.4.2] with current compatibility version [7.4.2] must be marked as read-only using the setting [index.blocks.write] set to [true] before upgrading to 9.0.1."
  "status" : 500
Index, as expected, still has the old version (you can also see the value of write):
  "settings": {
    "index": {
      "routing": {
        "allocation": {
          "require": {
            "type": "*****"
      "number_of_shards": "1",
      "blocks": {
        "read_only": "false",
        "write": "true"
      "provided_name": "******",
      "creation_date": "******",
      "history": {
        "uuid": "******"
      "number_of_replicas": "1",
      "uuid": "YbjRW****",
      "version": {
        "created": "7040299",
        "upgraded": "7090299"
Is there anything else we can try? That "minimum_index_compatibility_version": "8.0.0" shows that we might not have luck without reindexing to v8.
Does "index.blocks.read_only" have any role during restore process? Should we try to remove and then re-add this index to the snapshot? Or perhaps to close the index before taking the snapshot?
Did you do that using the put index block API I mentioned above or just by adjusting the setting directly? You need to use the API.
@DavidTurner
I edited my previous post - I added GET / output from v9 cluster (the one that matters actually) and this one shows "minimum_index_compatibility_version": "8.0.0".
To set the index settings I was using Elasticsearch API: curl ... -X PUT "$ES_HOST/$index/_settings -d ... and passing json like this as data:
  "index": {
    "blocks": {
      "write": "true"
Response would be:
  "acknowledged": true
And when observing the index settings I could see that new value is applied.
Let me try to use that API in Kibana and I will post here the test result.
@DavidTurner Using that index _block API worked! We managed to restore the v7 index from v8 snapshot into v9 Elasticsearch.
  1. Used Kibana UI to remove the existing "index.blocks" object in order to get index settings to clean state
  2. In Kibana DevTools executed PUT /my_index/_block/write. The response was:
  "acknowledged": true,
  "shards_acknowledged": true,
  "indices": [
      "name": "my_index",
      "blocked": true
  1. Created a new snapshot (in Elastic v8)
  2. Restored it into Elastic v9 (result also verified in Kibana UI)
  "accepted" : true
Many thanks for advising using _block API. That saved the day!
Now, I have 2 more questions.
(1) We tried to remove the "index.blocks.write" (to unblock the index and make it writeable again) with DELETE /data_partnership_sources/_block/write but that failed with:
  "error": "Incorrect HTTP method for uri [/my_index/_block/write?pretty=true] and method [DELETE], allowed: [PUT]",
  "status": 405
How to reverse the PUT /my_index/_block/write action? One idea is to use again Elastic _settings API but it might only change the settings without doing some extra work to undo what _block API changed under the bonnet (which was seemingly not just changing index settings).
(2) Also, index still has "version.created":"7040299" but Elastic v9.0.1 shows "minimum_index_compatibility_version": "8.0.0". Would this make problems in future? How to make sure that we would be able to restore this index in future Elastic versions (e.g. v10)? Would you advise reindexing it?
Great, thanks for confirming that :slight_smile:
Yes, the settings API is the right way to remove the block. But you're right DELETE /my_index/_block/write makes a lot more sense now that you mention it. More usability bugs...
However you won't be able to remove the block: an 9.x Elasticsearch cluster can read 7.x indices but it can't write to them. You will need to reindex it to get a writeable copy of the data. Sorry, I didn't realise that's what you wanted in the first place otherwise I'd not have taken you down the write-block path.
Not a problem, just reflecting that this index is not fully compatible with this ES version. In particular, it doesn't know how to write to such old indices any more.
I opened the following issues to follow up from the snags mentioned above:
