Snapshots - restoring an index from a large repository with long term storage (LTO ...)
I have a classic question about snapshots in elasticsearch.
I make elasticsearch snapshots to some repository - for example, let it be some Network File System (NFS) or similar.
Later this snapshot from this network storage goes to other media - for example, tapes LTO or BD-ROM.
The question is simple:
There are 10 indexes in the repository.
What if I only want to restore 1 index?
Do I have to load the entire repository into NFS from the tape (some long term medium) and then recover only one index from elasticsearch?
Is there any idea that I need to retrieve only one index from the LTO/BD-ROM?
Limiting yourself to just the index you need can save you a lot of time.
Yes.
Well....
In real systems, what are the models for creating repositories?
Create fewer large repositories or more but smaller repositories?
Repository size here can be a big role.
Are there any effective approaches when you are not sure what you are must recovery in future?
Today there are a handful of recognised problems with using offline/long-term storage for backups:
  • There isn't even a procedure for correctly copying a registered repository to tape.
  • As you discovered here, there isn't really a procedure for selectively restoring certain indices from offline storage (e.g. AWS Glacier, but the fix for tape would be similar IMO).
  • Version N cannot restore snapshots from versions before version N-1 (I don't even see a Github issue for this).
The fact that we don't get very many comments or +1s on those issues indicates it's not something that a lot of folks are trying to do. There are workarounds, although they're not ideal:
  • Unregister the repository each time you copy it to tape.
  • Use more repositories, each containing a subset of indices.
  • Reindex your whole archive at each major version upgrade.
Please feel free to indicate your need for these features on the issues I linked above.
