[SOLVED] Problem to create and test index manually
Hi all,
I try to make some tests but unsuccessful.
I try to create an test index:
curl -XPUT localhost:9200/test -d@index_template_test.txt
index-template-test.txt file:
      "settings" : {
              "analysis": {
                  "tokenizer": {
                      "custom-pattern-tokenizer": {
                          "type": "pattern",
                          "pattern": "."
                  "analyzer": {
                      "custom-analyzer": {
                          "type": "custom",
                          "tokenizer": "custom-pattern-tokenizer"
      "mappings": {
          "my_type": {
              "properties": {
                  "source_host": {
                      "type": "string",
                      "index": "analyzed",
                      "analyzer": "custom-analyzer"
After, I put data:
curl -XPUT localhost:9200/test/my_type/1 -d'
"source_host" : "mytest-test-1.fr"
When I made a global search, I get an answer:
curl -XGET localhost:9200/test/_search?pretty
  "took" : 3,
  "timed_out" : false,
  "_shards" : {
    "total" : 5,
    "successful" : 5,
    "failed" : 0
  "hits" : {
    "total" : 1,
    "max_score" : 1.0,
    "hits" : [ {
      "_index" : "test",
      "_type" : "my_type",
      "_id" : "1",
      "_score" : 1.0,
      "_source" : {
But when I make a specific search, it returns nothing:
curl -XGET localhost:9200/test/my_type/_search?pretty=true -d'
        "match": {
  "took" : 1,
  "_shards" : {
    "total" : 5,
    "successful" : 5,
    "failed" : 0
  "hits" : {
    "total" : 0,
    "max_score" : null,
    "hits" : [ ]
So I can't make some test with _analyze right now. Do you have any idea why I can't return a result with this kind of search ?
Result when I try an _analyze:
curl -XGET 'localhost:9200/test/_analyze?pretty&analyzer=custom-analyzer' -d mytest-test-1.fr
  "tokens" : [ ]
Thanks in advance,
Alex
After some tests, I don't understand really...
I created an index, and I put data:
 "source_host": "mytest-test-1.fr"
{"_index":"test","_type":"my_type","_id":"1","_version":1,"_shards":{"total":2,"successful":2,"failed":0},"created":true}
When I retry to make a specific search like below, I get nothing:
curl -XGET localhost:9200/test/my_type/_search?pretty -d'
"term": { "source_host": "mytest-test-1.fr"}
  "took" : 1,
  "_shards" : {
    "total" : 5,
    "successful" : 5,
    "failed" : 0
  "hits" : {
    "total" : 0,
    "max_score" : null,
    "hits" : [ ]
But with this request, I get result:
curl -XGET localhost:9200/test/my_type/_search?pretty&q=source_host:mytest-test-1.fr
  "took" : 4,
  "_shards" : {
    "total" : 5,
    "successful" : 5,
    "failed" : 0
  "hits" : {
    "total" : 1,
    "max_score" : 1.0,
    "hits" : [ {
      "_index" : "test",
      "_id" : "1",
      "_score" : 1.0,
      "_source" : {
Somebody can explain me why ? I become crazy about that !
Thanks in advance,
Alex
I found the problem. It was an indexing problem. My custom analyzer doesn't work so my indexation too.
Have a good day.
