Sort search results when sorted by double_range or float_range field return array_index_out_of_bounds_exception
Hello experts,
I'm currently trying to sort search results by double_range or float_range field,but return a server error:array_index_out_of_bounds_exception,I've included the query and the error output, is this supported, and/or is there any workarounds?
this is mapping setting:
this is documents
this is request body and results
POST */_search
    "_source":true,
    "aggs":{
    "from":0,
    "highlight":{
        "fields":{
                "fragment_size":10000
        "post_tags":[
            "@/kibana-highlighted-field@"
        "pre_tags":[
            "@kibana-highlighted-field@"
        "require_field_match":false
    "query":{
        "bool":{
            "filter":[],
            "must":[
                    "query_string":{
                        "analyze_wildcard":true,
                        "default_field":"*",
                        "lenient":true,
                        "query":"*",
                        "type":"phrase"
            "must_not":[],
            "should":[]
    "size":10,
    "sort":[
            "double_range":{
                "missing":"_last",
                "order":"desc",
                "unmapped_type":"double_range"
Looking forward to any help! Thank you!
Are there someone can help me?Thanks!
