Hello, I am using Elasticsearch to index logs from Kubernetes. I have the problem, that in Kibana (6.8.6) discover, visualize, etc. I can only see the logs coming from one pod, namely the kibana pod itself, in namespace logging.
For example, I take the index fluentbit-2020.09.28, which I see has around 3090646 indexed documents:
[ec2-user@ip-10-105-6-233:~ ] es-api.sh _cat/indices?v
health status index uuid pri rep docs.count docs.deleted store.size pri.store.size
green open fluentbit-2020.09.28 I_lfFz-ISlKA5EGhNutvYg 5 1 3090646 0 5gb 2.5gb
With a search I try to see from which kubernetes namespaces I am receiving logs, and I see that there certainly are documents there in other namespaces than logging:
GET fluentbit-2020.09.28/_search
"aggregations": {
"namespaces": {
"terms": {
"field": "kubernetes.namespace_name.keyword"
#Response:
"took" : 182,
"timed_out" : false,
"_shards" : {
"total" : 5,
"successful" : 5,
"skipped" : 0,
"failed" : 0
"aggregations" : {
"namespaces" : {
"doc_count_error_upper_bound" : 0,
"sum_other_doc_count" : 4,
"buckets" : [
"key" : "acc",
"doc_count" : 489132
"key" : "trn",
"doc_count" : 433474
"key" : "tst",
"doc_count" : 389724
"key" : "dev1",
"doc_count" : 387572
"key" : "dev3",
"doc_count" : 357916
"key" : "dev2",
"doc_count" : 357874
"key" : "acc-freetext",
"doc_count" : 335400
"key" : "kube-system",
"doc_count" : 194104
"key" : "monitoring",
"doc_count" : 64900
"key" : "logging",
"doc_count" : 8512
But the problem is that in Kibana there is nothing to be seen, neither in Discover nor in Visualize:
I tried to find the XHR which Kibana makes at the _msearch endpoint, and call it:
POST _msearch
{"index":"fluentbit-2020.09.28","ignore_unavailable":true,"preference":1601279552404}
{"version":true,"size":500,"sort":[{"@timestamp":{"order":"desc","unmapped_type":"boolean"}}],"_source":{"excludes":[]},"aggs":{"2":{"date_histogram":{"field":"@timestamp","interval":"30m","time_zone":"Europe/Berlin","min_doc_count":1}}},"stored_fields":["*"],"script_fields":{},"docvalue_fields":[{"field":"@timestamp","format":"date_time"},{"field":"@timestamp-es","format":"date_time"},{"field":"data.createdOn","format":"date_time"},{"field":"data.editedOn","format":"date_time"},{"field":"data.expectedEnd","format":"date_time"},{"field":"data.expiringDate","format":"date_time"},{"field":"data.messages.createdOn","format":"date_time"},{"field":"expectedEnd","format":"date_time"},{"field":"kubernetes.annotations.kubectl_kubernetes_io/restartedAt","format":"date_time"},{"field":"request_received_at","format":"date_time"},{"field":"response_sent_at","format":"date_time"},{"field":"time","format":"date_time"},{"field":"timestamp","format":"date_time"},{"field":"ts","format":"date_time"},{"field":"written_at","format":"date_time"}],"query":{"bool":{"must":[{"range":{"@timestamp":{"gte":1601193592568,"lte":1601279992568,"format":"epoch_millis"}}}],"filter":[{"bool":{"should":[{"match":{"kubernetes.namespace_name":"logging"}}],"minimum_should_match":1}}],"should":[],"must_not":[]}},"highlight":{"pre_tags":["@kibana-highlighted-field@"],"post_tags":["@/kibana-highlighted-field@"],"fields":{"*":{}},"fragment_size":2147483647},"timeout":"30000ms"}
And I get actual results with the above query. But if I then substitute in the term "match": {"kubernetes.namespace_name":"logging"}, "logging" with "monitoring", I get no results:
"responses" : [
"took" : 4,
"_shards" : {
"total" : 5,
"successful" : 5,
"skipped" : 0,
"failed" : 0
"hits" : {
"total" : 0,
"max_score" : null,
"hits" : [ ]
"aggregations" : {
"2" : {
"buckets" : [ ]
"status" : 200
So the data seems to be in elasticsearch but I somehow cannot retrieve it?
I cannot think of a reason, other than that I had indeed in the past searched for "kubernetes.container_name: kibana" in Discover. To me it seems as if this search has been persisted and I can no longer get rid of it. I have in the meantime also deleted the .kibana_1 index and restarted Kibana, to no avail.
