Upgrade from 5.6 to 6.0. Problem with mapping
Hello!
I'm using Elastic stack to collect logs from application nodes. My setup is: Filebeat -> Logstash -> Elasticsearh.
I have upgraded my cluster from version 5.6 to version 6.0. Cluster consists of 5 nodes: 1 master, 2 hot nodes, 2 cold nodes.
Elasticsearch has been upgraded on all nodes plus Logstash node. Also I did changes in index template.
Now it looks like this:
      "index_patterns": "logstash-*",
      "settings": {
        "index.refresh_interval": "5s",
        "index.number_of_shards": 2,
        "index.number_of_replicas": 1,
        "index.routing.allocation.require.box_type": "hot"
      "mappings": {
        "_default_": {
          "_all": {
            "enabled": false,
            "omit_norms": true
          "dynamic_templates": [
              "message_field": {
                "match": "message",
                "match_mapping_type": "string",
                "mapping": {
                  "type": "text",
                  "index": "analyzed",
                  "omit_norms": true
              "strings": {
                "match": "*",
                "mapping": {
                  "type": "text",
                  "omit_norms": true,
                  "fields": {
                    "keyword": {
                      "type": "text",
                      "index": "not_analyzed",
                      "ignore_above": 256
          "properties": {
            "@version": {
              "type": "text"
            "geoip": {
              "type": "object",
              "dynamic": true,
              "properties": {
                "location": {
                  "type": "geo_point"
Unfortunately, I still can't get new data, only error in Logstash:
[WARN ][logstash.outputs.elasticsearch] Could not index event to Elasticsearch. {:status=>400, :action=>["index", {:_id=>nil, :_index=>"logstash-application-2017.12.12-11", :_type=>"doc", :_routing=>nil}, #<LogStash::Event:0x276c821b>], :response=>{"index"=>{"_index"=>"logstash-application-2017.12.12-11", "_type"=>"doc", "_id"=>nil, "status"=>400, "error"=>{"type"=>"mapper_parsing_exception", "reason"=>"Failed to parse mapping [_default_]: No handler for type [string] declared on field [@version]", "caused_by"=>{"type"=>"mapper_parsing_exception", "reason"=>"No handler for type [string] declared on field [@version]"}}}}}
Are you sure that this is the template that gets used? Do you have other active templates in your cluster?
Same with me, in ES6, i got many problem with index template :cry:
Thank you!
I didn't delete old one. So stupid mistake :slight_smile:
