We are using the Elastic version v 7.16.3 .
I am trying to create the alert notification by using the Rules and connectors.
The rule is working fine. however I can't put the required data in the e-mail notification that I generate.
Test case 1: If I use the template e-mail in elastic no issue.
Test case 2: If i want to add more data and use the {{context.hits._index}} and get to the content of index and use the dot.dot to grab the data it is not working. Th mustach variable is not working. I reached out to everyone and still no resolution.
Sample screenshot of generated alert
Massage body is :
Elasticsearch query alert '{{alertName}}' is active:
- Value: {{context.value}}
- Conditions Met: {{context.conditions}} over {{params.timeWindowSize}}{{params.timeWindowUnit}}
- Timestamp: {{context.date}}
-**indextest:** *{{context.hits._index}}* is
