Watcher input, simple query without body
Hi I wanto to run a Watch with the disk space available in a node, but I dont know how to use this query:
GET _cat/nodes?h=h,diskAvail
in the context of the Watcher input, because this query has no body, no indices to use, nor timestamp.
How can I do this?
Example of a normal Watcher input
"input": {
    "search": {
      "request": {
        "indices": [
          "index*"
        "rest_total_hits_as_int": true,
        "body": {
          "size": 0,
            "bool": {
              "filter": {
                "range": {
                  "@timestamp": {
                    "gte": "{{ctx.trigger.scheduled_time}}||-5m",
                    "lte": "{{ctx.trigger.scheduled_time}}",
                    "format": "strict_date_optional_time||epoch_millis"
Hi!
Instead of search input, you can use http input
There is a related example in the documentation: https://www.elastic.co/guide/en/elasticsearch/reference/current/watch-cluster-status.html
If you use monitoring, there is also a related example that leverages the internal indexes used for that feature and search input:
Gracias Andres!
