Watcher using filter range with time does not fire
Hello. I have been trying to write a Watcher that looks for specific conditions in data and then send out an email, but it doesn't work. I have managed to shrink the Watcher down to a bare minimum and have found out that my filter range expression using time does not work. When I run the Watcher in the simulation the Watcher does not fire.
The line that is not working is
 "range": {
   "doc['@timestamp'].date.millisOfDay": {
     "gte": 0,
     "lte": 21870000
Basically the filter range statement should return any documents where the timestamp is between midnight and 6:45 UTC. I don't know why it is not working!
The Watcher interval is 30 minutes and the range of data being looked at is 7 days for debugging purposes.
We are using Elastic Cloud version 7.8
Complete watcher code
  "trigger": {
"schedule": {
  "interval": "30m"
  "input": {
"search": {
  "request": {
    "indices": [
      "filebeat-*"
    "rest_total_hits_as_int": true,
    "body": {
      "size": 0,
        "bool": {
          "filter": [
              "range": {
                "@timestamp": {
                  "gte": "{{ctx.trigger.scheduled_time}}||-7d",
                  "lte": "{{ctx.trigger.scheduled_time}}",
                  "format": "strict_date_optional_time||epoch_millis"
              "range": {
                  "gte": 0,
                  "lte": 21870000
      "aggs": {
        "bucketAgg": {
          "terms": {
            "field": "almqueue",
            "size": "1",
            "order": {
              "metricAgg": "desc"
          "aggs": {
            "metricAgg": {
              "max": {
                "field": "almqueue"
  "condition": {
"script": {
  "source": "ArrayList arr = ctx.payload.aggregations.bucketAgg.buckets; for (int i = 0; i < arr.length; i++) { if (arr[i]['metricAgg'].value > params.threshold) { return true; } } return false;",
  "lang": "painless",
  "params": {
    "threshold": 2300
  "actions": {
"email_1": {
  "email": {
    "profile": "standard",
    "to": [
      "ajazam@company.com"
    "subject": "Watch [{{ctx.metadata.name}}] for time 04:45 - 06:45 has exceeded alarm threshold of 2300"
There isn't anything wrong with the watcher. The problem was with a second visualization I was using, that was rendering the wrong data, which I was using as a comparison.
