Background:
elasticsearch: 0.90.0
Java: 1.7.17
I'm using daily indexes for logging data. As time goes on, I'd like fewer
copies of the data in the cluster as it's less critical. The index being
manipulated is already optimized and is no longer taking writes on a 3 node
cluster. I tried playing with shards_per_node and number_of_replicas, but
the routing logic often left an unallocated shard:
"settings" : {
"index.number_of_shards" : 3,
"index.number_of_replicas" : 1,
"index.routing.allocation.total_shards_per_node" : 2,
"index.auto_expand_replicas": false
Ideally this means:
Node 1: [0], [1]
Node 2: [1], [2]
Node 3: [0], [2]
But what happened frequently was:
Node 1: [0], [1]
Node 2: [0], [1]
Node 3: [2]
Unallocated: [2]
So, new idea. Use the day number, and the node index to implement a
routing decision, each node sets an "id" attribute:
Node 1: node.id: 0
Node 2: node.id: 1
Node 3: node.id: 2
Take the index's day of year and modulus the number of nodes to set:
logstash-2013.01.01 then:
index.routing.allocation.exclude = 1
This has no effect on the shards from what I can see, because it needs to
meet the replicas quota of 2. Once the exclude is set, I downgrade the
number of replicas to 1:
index.number_of_replicas = 1
What I thought would happen: The node flagged as excluded drops it's shards.
What actually happens: The primary shards for the index are left where
they are and a replica of that shard is dropped from a node. Now, the
routing/allocation takes over and says "hey, that shard shouldn't be there"
and then begins copying the shards off the excluded node to nodes which
previously had these shards but dropped them because of the replicas
change. This results in a MASSIVE traffic spike as these indexes (just
in testing at this point) are ~65GB each.
Am I doing something wrong, or is this a bug in how this logic is being
handled?
Thanks,
Brad Lhotsky
