What does setting dis_max exactly do in a query_string query?
I'm running a query as follows:
  • query: {
    query_string: {
    - query: "china"
    - default_operator: "AND"
    - use_dis_max: true
    fields: [
    - "headline"
    - "byline"
    - "body"
I've been toggling use_dis_max on and off but can't seem to decipher what
exactly is going on. From the Elasticsearch documentation, dis_max is
mentioned as "Since several queries are generated, combining them can be
automatically done either using a dis_maxquery or a simple bool query. "
What exactly is meant by combining them? I understand individual queries
are run for my query term ('china') to be run against each field specified
and documents with that field matching my term are returned with a score,
but what happens afterward? From dis_max query documentation, I assume the
highest score for a document is returned, but how about when I set
use_dis_max to false then? At least from what I'm seeing with my data set,
setting dis_max to false or true produces identical results.
Here is a great blog post about DisMax:
http://searchhub.org/2010/05/23/whats-a-dismax/
Ivan
  • query: {
    query_string: {
    - query: "china"
    - use_dis_max: true
    fields: [
    - "headline"
    - "byline"
    - "body"
