i'd like to use Cross Cluster Search between two clusters (ES version: 5.6).
For example i'd like to see data from cluster A to cluster B; I'd like to know if there is the need to open the flow in bidirectional way on port 9300 or if it is enough to open the flow only from cluster A to cluster B.
Thanks a lot.
Federica Forti | Elastic Certified Consultant
