I Had two nodes independant not part of the cluster. I used logstash to index on each node. After i figured to configure the cluster, I added 2 nodes and one as client for kibana. Now when I start the cluster it repeadeatily says . Also from one node to another tried to reallocate beacause there was no space. Should i reindex from each node to a new cluster or is there another solution to fix this. I checked and the same index folder name lives in each host. All of the just only hava one partition primary. Any help?
Thanks in advance
2017-10-19T23:29:14,110][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.25/jXNhRD7TS0G3KUqmEzl45A]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,110][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.09.11/gu_0gqhYSNujnRyGslWAhA]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.21/hvbFhJD1T0KgBRb3MB9Ykw]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.10.03/7AnST3UTTtmws6vOoKyzAA]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.10.13/c8IN-0VnRRKmbfFCIUsO7g]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.10.14/pmf0pTU6TLSUa3BjRZzc2Q]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.26/vcrAK1NcRFeNcGgyOGwbYQ]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.09.19/urUEahI7QR-nnWMyGHsX4g]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.09.30/_Y5twyChRCOA-JcxxWoQog]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.27/wh52B0eFQSmsMzJrbxeBDw]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,111][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.06.12/BmcRV6dQQ42qQajckDJlxw]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,112][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.09.18/01apjfTVQTSABChxM2E0TA]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,112][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.01/vyNFxLhxSnumnRqL6E0Kcg]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,112][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.07.26/Il0TmOxqQo6gJFxUeqdLNQ]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,112][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.08.15/qNqJP5XfTUe5qSacYKZtUw]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-10-19T23:29:14,112][WARN ][o.e.g.DanglingIndicesState] [pgdcone-es02] [[claro-osb-all-2017.09.22/MLzbZ6D-Q-67MORifRj8tQ]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
