INDEX_NAME can not be imported as a dangling index, as index with same name already exists in cluster metadata
I have the following warnings in the log every day on a specific node:
(this repeats 285 times for the same 2 indexes)
[2017-01-19T00:53:30,171][WARN ][o.e.g.DanglingIndicesState] [LXS2jYx] [[card-views-and-searches-2016-12-05/-9uq5LO3RZ-zSAlzB_ojtg]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
[2017-01-19T00:53:30,171][WARN ][o.e.g.DanglingIndicesState] [LXS2jYx] [[card-views-and-searches-2016-12-04/8wWRi8vsQFiQhIotXXLTWQ]] can not be imported as a dangling index, as index with same name already exists in cluster metadata
The logs seem to appear around the time our daily snapshot job runs:
[2017-01-19T00:53:29,818][INFO ][o.e.s.SnapshotShardsService] [dJor1ik] snapshot [s3-elasticsearch-snapshots:production-elasticsearch-backup-2017-01-19/-g85pwS2QRm3ALwY7gvS8w] is done
It seems it only happened to those 2 indexes.
card-views-and-searches-* is a index template
Environment details:
Production kubernetes cluster
Docker image
elasticsearch:5.0.0
Plugins:
RUN ./bin/elasticsearch-plugin install repository-s3
RUN ./bin/elasticsearch-plugin install io.fabric8:elasticsearch-cloud-kubernetes:5.0.0
3 elasticsearch containers with node affinity (1 per node) and with volume to the node fs
Anyone has any idea what caused this and how to fix it?
Thanks in advance.
