Hello, tell me what am I doing wrong?
I downloaded the dashboards from here. https://artifacts.elastic.co/downloads/beats/beats-dashboards/beats-dashboards-6.6.0.zip
I'm going to the kibana interface -> Management -> SavedObjects -> imports
Thanks for the help.
Hi, I believe the Beats dashboards zip at that path is meant for use with the Beats setup command: https://www.elastic.co/guide/en/beats/devguide/6.6/import-dashboards.html They will not work with the Saved Objects interface.
All clear. Thanks for the answer.
