Discover fails with "content length bigger than max allowed string" on index with large text field
Hello Connections,
We're facing an issue when trying to retrieve documents in Discover, and wanted to get community input on the best long-term fix.
Environment:
  • Elastic Stack version: [8.19.3]
  • Deployment: self-managed on EC2
  • Ingestion path: Filebeat → Logstash → Elasticsearch
The error:
When loading Discover against one of our production data views (index-* indices), we get:
Root cause we've identified:
One field in our documents (a payload/raw_payload text field, is extremely large on a subset of documents — we found individual documents as large as ~23MB in a single index, versus ~2KB for typical documents in the same index. When Discover's default query returns full _source for a batch of matched hits, the aggregate response for even a short time window (minutes, not hours) exceeds ~512MB and the browser fails to parse it.
We need to have the document and where the payload is in event.original
Any suggestion to fix
Thanks in advance
welcome to the forum @Mouly_Infy
This has been asked directly or indirectly a couplee of times, e.g. here
See this github thread too for some ideas.
You need be careful here too as other clients (not just Kibana/Discover) can hit issues with large HTTP payloads. I dont know your use case and what you are specifically trying to do, but it's unlikely there is much value in "seeing" a 23 MB document within Kibana.
