HI,i am trying to connect to sql database and feed data to elastic search engine.i used sense to feed data
PUT http://localhost:9200/_river/orders_river/_meta
"type":"jdbc",
"jdbc":
"driver": "com.microsoft.sqlserver.jdbc.SQLServerDriver",
"url":"jdbc:sqlserver://usalvwaldbqa1:1433;databaseName=es",
"user":"es",
"password":"Answ3r21",
"sql":"SELECT top 1 solution_id FROM es.g_solution",
"index" : "clients",
"type" : "orders"
but I got below error:
[discovery.zen.ping.multicast] [Vibro] multicast failed to start [SocketException[An invalid argument was supplied]], disabling. Consider using IPv4 only (by defining env. variable ES_USE_IPV4)
Looks like I need to change some settings in yml ,but not clear.
elastic.yml:
##################### Elasticsearch Configuration Example #####################
This file contains an overview of various configuration settings,
targeted at operations staff. Application developers should
consult the guide at http://elasticsearch.org/guide.
The installation procedure is covered at
http://elasticsearch.org/guide/en/elasticsearch/reference/current/setup.html.
Elasticsearch comes with reasonable defaults for most settings,
so you can try it out without bothering with configuration.
Most of the time, these defaults are just fine for running a production
cluster. If you're fine-tuning your cluster, or wondering about the
effect of certain configuration option, please do ask on the
mailing list or IRC channel [http://elasticsearch.org/community].
Any element in the configuration can be replaced with environment variables
by placing them in ${...} notation. For example:
#node.rack: ${RACK_ENV_VAR}
For information on supported formats and syntax for the config file, see
http://elasticsearch.org/guide/en/elasticsearch/reference/current/setup-configuration.html
################################### Cluster ###################################
Cluster name identifies your cluster for auto-discovery. If you're running
multiple clusters on the same network, make sure you're using unique names.
#cluster.name: elasticsearch
#################################### Node #####################################
Node names are generated dynamically on startup, so you're relieved
from configuring them manually. You can tie this node to a specific name:
#node.name: "Franz Kafka"
Every node can be configured to allow or deny being eligible as the master,
and to allow or deny to store the data.
Allow this node to be eligible as a master node (enabled by default):
#node.master: true
Allow this node to store data (enabled by default):
#node.data: true
You can exploit these settings to design advanced cluster topologies.
1. You want this node to never become a master node, only to hold data.
This will be the "workhorse" of your cluster.
#node.master: false
#node.data: true
2. You want this node to only serve as a master: to not store any data and
to have free resources. This will be the "coordinator" of your cluster.
#node.master: true
#node.data: false
3. You want this node to be neither master nor data node, but
to act as a "search load balancer" (fetching data from nodes,
aggregating results, etc.)
#node.master: false
#node.data: false
Use the Cluster Health API [http://localhost:9200/_cluster/health], the
Node Info API [http://localhost:9200/_nodes] or GUI tools
such as http://www.elasticsearch.org/overview/marvel/,
http://github.com/karmi/elasticsearch-paramedic,
http://github.com/lukas-vlcek/bigdesk and
http://mobz.github.com/elasticsearch-head to inspect the cluster state.
A node can have generic attributes associated with it, which can later be used
for customized shard allocation filtering, or allocation awareness. An attribute
is a simple key value pair, similar to node.key: value, here is an example:
#node.rack: rack314
By default, multiple nodes are allowed to start from the same installation location
to disable it, set the following:
#node.max_local_storage_nodes: 1
#################################### Index ####################################
You can set a number of options (such as shard/replica options, mapping
or analyzer definitions, translog settings, ...) for indices globally,
in this file.
Note, that it makes more sense to configure index settings specifically for
a certain index, either when creating it or by using the index templates API.
See http://elasticsearch.org/guide/en/elasticsearch/reference/current/index-modules.html and
http://elasticsearch.org/guide/en/elasticsearch/reference/current/indices-create-index.html
for more information.
Set the number of shards (splits) of an index (5 by default):
#index.number_of_shards: 5
Set the number of replicas (additional copies) of an index (1 by default):
#index.number_of_replicas: 1
Note, that for development on a local machine, with small indices, it usually
makes sense to "disable" the distributed features:
#index.number_of_shards: 1
#index.number_of_replicas: 0
These settings directly affect the performance of index and search operations
in your cluster. Assuming you have enough machines to hold shards and
replicas, the rule of thumb is:
1. Having more shards enhances the indexing performance and allows to
distribute a big index across machines.
2. Having more replicas enhances the search performance and improves the
cluster availability.
The "number_of_shards" is a one-time setting for an index.
The "number_of_replicas" can be increased or decreased anytime,
by using the Index Update Settings API.
Elasticsearch takes care about load balancing, relocating, gathering the
results from nodes, etc. Experiment with different settings to fine-tune
your setup.
Use the Index Status API (http://localhost:9200/A/_status) to inspect
the index status.
#################################### Paths ####################################
Path to directory containing configuration (this file and logging.yml):
#path.conf: /path/to/conf
Path to directory where to store index data allocated for this node.
#path.data: /path/to/data
Can optionally include more than one location, causing data to be striped across
the locations (a la RAID 0) on a file level, favouring locations with most free
space on creation. For example:
#path.data: /path/to/data1,/path/to/data2
Path to temporary files:
#path.work: /path/to/work
Path to log files:
#path.logs: /path/to/logs
Path to where plugins are installed:
#path.plugins: /path/to/plugins
#################################### Plugin ###################################
If a plugin listed here is not installed for current node, the node will not start.
#plugin.mandatory: mapper-attachments,lang-groovy
################################### Memory ####################################
Elasticsearch performs poorly when JVM starts swapping: you should ensure that
it never swaps.
Set this property to true to lock the memory:
#bootstrap.mlockall: true
Make sure that the ES_MIN_MEM and ES_MAX_MEM environment variables are set
to the same value, and that the machine has enough memory to allocate
for Elasticsearch, leaving enough memory for the operating system itself.
You should also make sure that the Elasticsearch process is allowed to lock
the memory, eg. by using ulimit -l unlimited.
############################## Network And HTTP ###############################
Elasticsearch, by default, binds itself to the 0.0.0.0 address, and listens
on port [9200-9300] for HTTP traffic and on port [9300-9400] for node-to-node
communication. (the range means that if the port is busy, it will automatically
try the next port).
Set the bind address specifically (IPv4 or IPv6):
#network.bind_host: 192.168.0.1
Set the address other nodes will use to communicate with this node. If not
set, it is automatically derived. It must point to an actual IP address.
#network.publish_host: 192.168.0.1
Set both 'bind_host' and 'publish_host':
#network.host: non_loopback:ipv4
Set a custom port for the node to node communication (9300 by default):
#transport.tcp.port: 9300
Enable compression for all communication between nodes (disabled by default):
#transport.tcp.compress: true
Set a custom port to listen for HTTP traffic:
#http.port: 9200
Set a custom allowed content length:
#http.max_content_length: 100mb
Disable HTTP completely:
#http.enabled: false
################################### Gateway ###################################
The gateway allows for persisting the cluster state between full cluster
restarts. Every change to the state (such as adding an index) will be stored
in the gateway, and when the cluster starts up for the first time,
it will read its state from the gateway.
There are several types of gateway implementations. For more information, see
http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-gateway.html.
The default gateway type is the "local" gateway (recommended):
#gateway.type: local
Settings below control how and when to start the initial recovery process on
a full cluster restart (to reuse as much local data as possible when using shared
gateway).
Allow recovery process after N nodes in a cluster are up:
#gateway.recover_after_nodes: 1
Set the timeout to initiate the recovery process, once the N nodes
from previous setting are up (accepts time value):
#gateway.recover_after_time: 5m
Set how many nodes are expected in this cluster. Once these N nodes
are up (and recover_after_nodes is met), begin recovery process immediately
(without waiting for recover_after_time to expire):
#gateway.expected_nodes: 2
############################# Recovery Throttling #############################
These settings allow to control the process of shards allocation between
nodes during initial recovery, replica allocation, rebalancing,
or when adding and removing nodes.
Set the number of concurrent recoveries happening on a node:
1. During the initial recovery
#cluster.routing.allocation.node_initial_primaries_recoveries: 4
2. During adding/removing nodes, rebalancing, etc
#cluster.routing.allocation.node_concurrent_recoveries: 2
Set to throttle throughput when recovering (eg. 100mb, by default 20mb):
#indices.recovery.max_bytes_per_sec: 20mb
Set to limit the number of open concurrent streams when
recovering a shard from a peer:
#indices.recovery.concurrent_streams: 5
################################## Discovery ##################################
Discovery infrastructure ensures nodes can be found within a cluster
and master node is elected. Multicast discovery is the default.
Set to ensure a node sees N other master eligible nodes to be considered
operational within the cluster. This should be set to a quorum/majority of
the master-eligible nodes in the cluster.
#discovery.zen.minimum_master_nodes: 1
Set the time to wait for ping responses from other nodes when discovering.
Set this option to a higher value on a slow or congested network
to minimize discovery failures:
#discovery.zen.ping.timeout: 3s
http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-discovery-zen.html
Unicast discovery allows to explicitly control which nodes will be used
to discover the cluster. It can be used when multicast is not present,
or to restrict the cluster communication-wise.
1. Disable multicast discovery (enabled by default):
#discovery.zen.ping.multicast.enabled: false
2. Configure an initial list of master nodes in the cluster
to perform discovery when new nodes (master or data) are started:
#discovery.zen.ping.unicast.hosts: ["host1", "host2:port"]
EC2 discovery allows to use AWS EC2 API in order to perform discovery.
You have to install the cloud-aws plugin for enabling the EC2 discovery.
http://elasticsearch.org/guide/en/elasticsearch/reference/current/modules-discovery-ec2.html
See http://elasticsearch.org/tutorials/elasticsearch-on-ec2/
for a step-by-step tutorial.
GCE discovery allows to use Google Compute Engine API in order to perform discovery.
You have to install the cloud-gce plugin for enabling the GCE discovery.
For more information, see https://github.com/elasticsearch/elasticsearch-cloud-gce.
Azure discovery allows to use Azure API in order to perform discovery.
You have to install the cloud-azure plugin for enabling the Azure discovery.
For more information, see https://github.com/elasticsearch/elasticsearch-cloud-azure.
################################## Slow Log ##################################
Shard level query and fetch threshold logging.
#index.search.slowlog.threshold.query.warn: 10s
#index.search.slowlog.threshold.query.info: 5s
#index.search.slowlog.threshold.query.debug: 2s
#index.search.slowlog.threshold.query.trace: 500ms
#index.search.slowlog.threshold.fetch.warn: 1s
#index.search.slowlog.threshold.fetch.info: 800ms
#index.search.slowlog.threshold.fetch.debug: 500ms
#index.search.slowlog.threshold.fetch.trace: 200ms
#index.indexing.slowlog.threshold.index.warn: 10s
#index.indexing.slowlog.threshold.index.info: 5s
#index.indexing.slowlog.threshold.index.debug: 2s
#index.indexing.slowlog.threshold.index.trace: 500ms
################################## GC Logging ################################
#monitor.jvm.gc.young.warn: 1000ms
#monitor.jvm.gc.young.info: 700ms
#monitor.jvm.gc.young.debug: 400ms
#monitor.jvm.gc.old.warn: 10s
#monitor.jvm.gc.old.info: 5s
#monitor.jvm.gc.old.debug: 2s
################################## Security ################################
Uncomment if you want to enable JSONP as a valid return transport on the
http server. With this enabled, it may pose a security risk, so disabling
it unless you need it is recommended (it is disabled by default).
#http.jsonp.enable: true
elastic .in.,sh
#!/bin/sh
ES_CLASSPATH=$ES_CLASSPATH:$ES_HOME/lib/elasticsearch-1.6.0.jar:$ES_HOME/lib/:$ES_HOME/lib/sigar/
if [ "x$ES_MIN_MEM" = "x" ]; then
ES_MIN_MEM=256m
fi
if [ "x$ES_MAX_MEM" = "x" ]; then
ES_MAX_MEM=1g
fi
if [ "x$ES_HEAP_SIZE" != "x" ]; then
ES_MIN_MEM=$ES_HEAP_SIZE
ES_MAX_MEM=$ES_HEAP_SIZE
fi
min and max heap sizes should be set to the same value to avoid
stop-the-world GC pauses during resize, and so that we can lock the
heap in memory on startup to prevent any of it from being swapped
out.
JAVA_OPTS="$JAVA_OPTS -Xms${ES_MIN_MEM}"
JAVA_OPTS="$JAVA_OPTS -Xmx${ES_MAX_MEM}"
new generation
if [ "x$ES_HEAP_NEWSIZE" != "x" ]; then
JAVA_OPTS="$JAVA_OPTS -Xmn${ES_HEAP_NEWSIZE}"
fi
max direct memory
if [ "x$ES_DIRECT_SIZE" != "x" ]; then
JAVA_OPTS="$JAVA_OPTS -XX:MaxDirectMemorySize=${ES_DIRECT_SIZE}"
fi
set to headless, just in case
JAVA_OPTS="$JAVA_OPTS -Djava.awt.headless=true"
Force the JVM to use IPv4 stack
if [ "x$ES_USE_IPV4" != "x" ]; then
JAVA_OPTS="$JAVA_OPTS -Djava.net.preferIPv4Stack=true"
fi
JAVA_OPTS="$JAVA_OPTS -XX:+UseParNewGC"
JAVA_OPTS="$JAVA_OPTS -XX:+UseConcMarkSweepGC"
JAVA_OPTS="$JAVA_OPTS -XX:CMSInitiatingOccupancyFraction=75"
JAVA_OPTS="$JAVA_OPTS -XX:+UseCMSInitiatingOccupancyOnly"
GC logging options
if [ "x$ES_USE_GC_LOGGING" != "x" ]; then
JAVA_OPTS="$JAVA_OPTS -XX:+PrintGCDetails"
JAVA_OPTS="$JAVA_OPTS -XX:+PrintGCTimeStamps"
JAVA_OPTS="$JAVA_OPTS -XX:+PrintClassHistogram"
JAVA_OPTS="$JAVA_OPTS -XX:+PrintTenuringDistribution"
JAVA_OPTS="$JAVA_OPTS -XX:+PrintGCApplicationStoppedTime"
JAVA_OPTS="$JAVA_OPTS -Xloggc:/var/log/elasticsearch/gc.log"
fi
Causes the JVM to dump its heap on OutOfMemory.
JAVA_OPTS="$JAVA_OPTS -XX:+HeapDumpOnOutOfMemoryError"
The path to the heap dump location, note directory must exists and have enough
space for a full heap dump.
#JAVA_OPTS="$JAVA_OPTS -XX:HeapDumpPath=$ES_HOME/logs/heapdump.hprof"
Disables explicit GC
JAVA_OPTS="$JAVA_OPTS -XX:+DisableExplicitGC"
Ensure UTF-8 encoding by default (e.g. filenames)
JAVA_OPTS="$JAVA_OPTS -Dfile.encoding=UTF-8"
